Could someone help me with why the build fails? It fails on fetching 1technophile/Arduino-Log#d13cd80 it seems.
On mac with latest vscode and Python 3.8.4 and 0.9.4 of OMG.
See error: https://paste.ubuntu.com/p/nhPpzGZs3K/
Edit: tried with cmd line pio and pio in virtualenv as well as using python 3.7 but same results
Try maybe to remove the #d13cd80
reference by using:
in platformio.ini file
1technophile:
#d13cd80
I tried this and it yielded the same result.
Did you tried to clean your environment with the little garbage in the bottom blue bar?
Try with this:
arduinolog = https://github.com/1technophile/Arduino-Log.git#d13cd80
EDIT:
the new arduino log worked. Now it fails on Library Manager: Installing 1technophile/rc-switch#8fc6d06
KeyError: ‘versions’:
EDIT2: I think it is the same. If I add the http url it works
This is due to evolutions in platformio, you have several solutions:
Replace each library call by the new format
instead of
arduinolog =1technophile/Arduino-Log#d13cd80
Use the development branch which is close to a beta stage
Thanks! I’ll try with the dev branch
