i try to use the manual setup with User_config.h file but it didn’t work
now it lost the wifi connection and i have to save the wifi setting again
why doesn’t it work with manual settings?
why it lost the wifi connection?
MQTTtoIR value || raw || datasring ok
raw
830,412,828,1254,402,446,800,418,402,418,404,1658,830,414,1250,412,404,32270,828,412,830,1252,404,444,802,414,432,388,408,1656,828,440,1222,414,404
Exception (28):
epc1=0x4022e924 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3fff0a30 end: 3fff0f30 offset: 01a0
3fff0bd0: 00000000 000f5547 3ffef9c8 00000030
3fff0be0: 00000000 00000000 00000000 00000000
3fff0bf0: 00000000 3fff0c20 00000001 4020aa04
3fff0c00: 3fff574a 4010523b 3fff1670 40208a48
3fff0c10: 00000022 00000000 00000093 00000000
3fff0c20: 00000001 00000000 3fff4350 00000008
3fff0c30: 00000001 00000000 00000014 3ffef297
3fff0c40: 3fff43e9 3ffef270 3fff0c60 4020b77f
3fff0c50: 40226978 3fff0c60 00000200 00000028
3fff0c60: 3fff0c50 3fff0c68 00000000 00000000
3fff0c70: 3fff434c 4023ca37 00000002 00000000
3fff0c80: 3fff4350 00000008 00000000 3ffed018
3fff0c90: 00000000 3ffef260 000f5695 4020a037
3fff0ca0: 3fff298c 00000000 00000020 000000ff
3fff0cb0: 0000005c 00000001 40104afe 3ffeda48
3fff0cc0: 00000005 00000000 00000020 401017b2
3fff0cd0: 3ffe9885 40104bb3 3ffed310 00000100
3fff0ce0: 401024c9 3ffed310 40104afe 3ffeda00
3fff0cf0: 00000005 00000000 00000020 401017b2
3fff0d00: 00000005 00000000 00000020 401017b2
3fff0d10: 00000000 00000000 00000020 401017b2
3fff0d20: 3ffe9880 40104b98 3ffed158 401017b2
3fff0d30: 00000001 40103dbb 3ffeda00 4010269a
3fff0d40: 4010421e 00000000 00000000 4010269a
3fff0d50: 00000000 3be89b4c 40102ada 00000100
3fff0d60: 40103d02 0000001d 7fffffff 00000000
3fff0d70: 0000011d 00000080 00000000 00000001
3fff0d80: 40102b77 00080000 00000000 4000050c
3fff0d90: 00000000 40102874 00000000 4000050c
3fff0da0: 3fffc278 40102874 3fffc200 00000022
3fff0db0: 3fff0dc0 00000000 0000001f 40105495
3fff0dc0: 4020bfd9 00000030 00000010 ffffffff
3fff0dd0: 4020bfcc 00003a98 000015a6 3ffefb14
3fff0de0: 00000020 00000020 00000000 40100c8d
3fff0df0: 3ffefb14 40220737 00000082 401009ac
3fff0e00: 00000000 00000000 3fff149c 3ffef297
3fff0e10: 0000009d 00000015 3ffef8a4 4021f5c4
3fff0e20: c025d463 3fff0e80 3fff0e80 4021f981
3fff0e30: 3ffefb14 00000658 00000658 401009ac
3fff0e40: 0000009d 3ffef270 3fff0e80 40100df0
3fff0e50: 0000009d 00000001 0000002c 3ffef297
3fff0e60: 3fff0c50 3fff43e9 3fff43e4 40100b0a
3fff0e70: 00000002 3ffef270 3fff434c 4020b81e
3fff0e80: 00000000 00000000 00000000 00000000
3fff0e90: 3fff0ec0 00000001 3ffef660 00000026
3fff0ea0: 000f5697 3ffef660 3ffef260 40225988
3fff0eb0: 000f5697 3ffef660 3ffef260 4020c114
3fff0ec0: 40252202 000f5697 00000000 00000001
3fff0ed0: 00000002 00000005 3ffef264 000000c8
3fff0ee0: 3fff4ebc 4020cae8 000f5697 3ffef9c8
3fff0ef0: 00000000 3ffef260 000f5697 4020b4f9
3fff0f00: 00000000 00000000 00000001 402212fd
3fff0f10: 3fffdad0 00000000 3ffef998 40221388
3fff0f20: feefeffe feefeffe 3ffe861c 40100e4d
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v951aeffa
~ld
mounting FS...
mounted file system
reading config file
opened config file
{"mqtt_server":"192.168.*.*","mqtt_port":"*","mqtt_user":"*","mqtt_pass":"*","mqtt_topic":"home/","gateway_name":"OpenMQTTGateway"}
parsed json
*WM: Adding parameter
*WM: server
*WM: port
*WM: user
*WM: pass
*WM: name
*WM: topic
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Waiting for connection result with time out
*WM: Connection timed out
*WM: Connection result:
*WM: 6
*WM:
*WM: Configuring access point...
*WM: OpenMQTTGateway
*WM: your_password
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started
