I found some issue with HCSR501 code, hope you add fix soon
config_HCSR501.h
#define HCSR501_PIN D5
, should be PIN number instead of D5
ZsensorHCSR501.ino
Missing timehcsr501
for calculating inverval between sending data, so device will send data continuously
//Time used to wait for an interval before resending data from hcsr501
unsigned long timehcsr501 = 0;
void MeasureHCSR501(){
if (millis() > (timehcsr501 + TimeBeforeStartHCSR501)) {//let time to init the PIR sensor
timehcsr501 = millis();
Hope you fix soon
