GS-WDS07 433Mhz Door sensor with open/close status
Thanks @PetricaM,
I have a second sensor now and will try to simulate that low battery state.
Your information is helpful - just one more clarification if you can:
So, when battery is low the sensor sends two signals when it gets into “open”?
It sends the code for “sensor open” and in addition “battery low”? That would be OK and good for me.
@eugeniogjr:
I think the code send as such is pretty clear - the system seems to be that the low battery code always is the “closed” code - 8.
Regards - MacSass
PS: I don´t see any of those sensors sold with the tamper switch installed anymore …
Hi,
It sends both open and battery low; however, (there are always limitations :slight_smile:) it sends both signals only when the battery is precisely at the low battery threshold.
Once it drops below this threshold it becomes too erratic and couldn’t identify a pattern: sometimes it sends low battery out of the blue (door is either open or closed), sometimes when opening it.
Thanks - I will put that in my code and see how it goes …if I get the low battery warning once, that should be enough …
Cheers - MacSass
I’ve got tons of this sensors. The following codes I have:
  • 0A - open
  • 0E - closed
  • 07 - tamper
  • 06 - low battery
I have connected a PIR module (an AM312 - Low current when inactive ~4uA - i did bypass the 3.3v LDO) across the reed switch connections, the STC micro in the WDS07 has a 3.3v feed into Pin 2, which i tapped off, i then re-housed the assembly in a waterproof box, i have placed this down my drive way to detect movement and the RF codes are read by a Sonoff Bridge into Home Assistant and decoded by Node Red - Works excellently and reliably.
Hi, i have a GS-WDS07 Sensor, can you help me with sensor for homeassistant, i receive the code for low battery but how i use it? thanks
hi,
a bit off topic maybe but…I have a couple of this sensor and using a gateway based on EspHome.
Usually to receive door sensors (I also have DIGOO switches) I set the receiver to rc_switch and dump the RF code (format is something like 10100101010) so binary one.
With these GS-WDS07 instead it seems I am not capturing anything: blue led is activating hence I guess it should be transmitting.
How are you doing to capture RF code?
I don’t quite get you.
Do you need help with receiving battery level or you don’t know how to use it in HA?
It would be useful if you could post a relevant bit of your sensor config here.
OMG sends all RF messages to a MQTT topic. Just subscribe to it an check what’s published when your sensor it tripped.
i have a 20 units GS-WDS07 , i wonder i i can convert it to water leak sensor ?
i have this water sensor
i try to soldering 2 wire to the reed but in my test its looks that the short not send the code.
mybe with tamper ? any idea ?
You should measure the impedance of the reed switch and try to replace it with a resistor with the same value first.
If working try to setup a circuit with your water sensor + the resistor or a lower one depending on the total impedance.
This sensor is a total of two pins that connect 2 wires and the water is supposed to shorten between them, I measured between the two REED legs and it gave 3.3V so that means it actually gives the trigger a trigger. The resistor you mean is actually going to simulate the resistance of the REED?
Because I shortened the sensor legs in a glass of water, it actually did nothing.
I am trying to understand the water sensor works whether it is really short or by lowering the resistance following the water.
Yes exactly
I think you should compare the impedance obtainer here with the reed switch one.
I measured the resistance on the REED and it gave me about 50 ohms.
The resistance on both connections after I removed the REED from the board is 1.5M ohms.
I put a 1.5M resistor between the two connections and connected the sensor but it did not help, if I put a resistor over 33K then no contact and still with the sensor is not a short sight to send the RF code.
I don’t really understand it, but I couldn’t really make the sensor a short character like the REED.
Do you have an idea or direction?
If you try to replace the REED with 50 ohms resistor or a close value do you succeed in triggering the sensor?
yes. i try many type of resistor values until 33Kohm . above 33K do nothing.
but with the resistor and the water sensor he do nothings
not 33K, 33ohms only and without the water sensor?
Yes I connected the resistor instead of the 33ohm resistor (I went up in values up to 33K) and it did give a trigger
any idea ?? :roll_eyes:
And the resistance of your water sensor when into the water is how much?
sorry cant remember now , i will check it and came back with the answer later
