Ahh updating to V709 got it working now seeing the BLE devices in the serial monitor and in HA, Yay
How does one decrease the time between scans from one minute to say 15 seconds?
1 Minute is a bit too long for my application.
I have found the setting for scan times and set it to what I need, appears to be working fine, Many thanks for your assistance in getting this working, you have a great attitude .Cheers John
I got this too:
> 19:12:36.959 -> OK
> 19:12:41.128 -> OK+Set:1
> 19:12:47.698 -> OK+Set:1
> 19:13:02.267 -> OK+RESET
> 19:13:15.347 -> OK+DISAS
> 19:13:16.067 -> OK+DISA:_⸮eux⸮e⸮L$⸮f⸮^⸮NǰK7⸮t⸮⸮⸮
> 19:13:16.352 -> OK+DISA:⸮⸮%rxH⸮
> 19:13:16.386 ->
> 19:13:16.386 -> ⸮L]m~⸮
> 19:13:16.597 -> OK+DISA:⸮e⸮⸮e⸮Ẇ⸮⸮⸮⸮7¹9⸮e⸮⸮
> 19:13:16.669 -> OK+DISA:⸮e⸮⸮
> 19:13:16.707 -> Mi Band 3⸮⸮
> 19:13:17.220 -> OK+DISA:̌⸮⸮⸮ְ⸮
> 19:13:17.255 -> ⸮⸮̌⸮⸮
> 19:13:17.292 -> OK+DISA:̌⸮⸮⸮ SWAN
> 19:13:18.876 -> OK+DISCE
I’m really stuck with this problem.
My story is: I set up a gateway with IR, RF, DHT, PIR and BT. Everything works except BT. I already changed firmware, communicated with BT via serial on the same ESP8266 that I use OMG and tested others two identical BT modules.
I don’t know where else to go.
Ahahaha
Ok! I understand that
“AT+ROLE1
AT+IMME1
AT+RESET
AT+DISA?”
is the new “abracadabra”!
Now it magically worked.
Thanks.
