Is it possible to add this device to OMG?
It works with 433MHz, but I wasn’t able to receive something with the RF module of OMG. I also tried the RF2 Kaku module.
Did you try with pilight also?
not yet. I will try.
Tried it with pilight in the meantime. Doesn’t work unfortunately.
I had to pair this device with the relay it controls, does this mean it doesn’t work with omg?
So if a device needs pairing it won’t work with OMG? Can we say that?
Not necessary, for example DG-LADA is paired but works with OMG.
It is more a matter of supported protocols.
Would it help to know the name of the protocol? I could try getting that information from the manufacturer.
Not really, the best way would be to do a reverse engineering with Pilight by using pilight-debug command.
Is there a documentation somewhere on who to do this?
I would still be interested in this
hello,
You can search on the pilight wiki or forum you should grab some info there
