Launch of the first hardware product powered by OpenMQTTGateway!
I’m happy to share with you the launch of Theengs Plug
The first product powered by OpenMQTTGateway out of the box.
The plug is available for North America customers and can:
  • Be controlled remotely
  • Act as a Bluetooth Gateway to retrieve data from sensors
  • Measure the energy consumption of the plugged device
Here are the characteristics:
Power Supply 100-120VAC, 60Hz
Max current 15A
Microcontroller ESP32
WiFi Band 2.4 GHz
Protocol MQTT
Operating Humidity 0%~95% (No condensation)
Operating Temperature 0 ºC ~ 40 ºC
Storage Temperature -10°C ~ 50°C
Dimensions 4.05in * 1.37in * 2.4in/103mm * 34.6mm * 61mm
Theengs Plug is UL certified.
The plug will be preloaded with OpenMQTTGateway and will support over 50 BLE devices.
