I have LILYGO TTGO LoRa32 (433MHz), and I use it as RF (rtl_433) gateway.
But I’m also trying to make DIY water level sensors using LoRa protocol because those sensors will be quite distant (around 250-300 meters) from the gateway.
So I just have a question. Is it possible to have the LoRa gateway and the rtl_433 gateway on the same device simultaneously?
Based on reading documentation about RF gateways, I think that this is not technically possible, and I will need two devices. But just in case, I asked.
Thanks a lot for this incredible project!
