I am very much new to arduino and its programming but slowly learning my way around.
Would like to know how to wire up the above AIO combination WITHOUT the need of a breadboard. Reason being I wish to have the AIO as compact as possible for use in a bedroom (within a 3D printed enclosure
Hi Florian,
Yes I did look at those 2 links. However, I am looking for a cable connection guide that does NOT require the use of a breadbox. As I am an arduino newbie, would appreciate any help.
Hi Florian,
I am not sure what I need, but I welcome any suggestions to any accessory that will help.
If possible, would be great if I just need to connect everything with jumpers
There is no ready to use shield for the configuration you are expecting.
You will have to breadboard or to solder if you want something on the long term.
