Dear DigiH,
Just to tell you I have installed last version “3ceb19” and it works perfectly after a system restart.
Thank a lot.
I also deleted the OMG device in HA and recreate it with another name to be sure it is completely referring to the last design.
One remark about scan in 1/100 sec.
Currently, I need to set the time through MQTT.
### Active Scan
isn’t it better to have the “active Scan” in second and be able to go up to 600000 (10 minutes) ?
For me 1 minut resolution is enough for meter t°/Hr.
As you say {“intervalacts”} is the additional separate interval for active scanning, which allows such sensors to be actively scanned at a lower frequency.
### Passive Scan
{“interval”} 100 ms if you have a PIR.
A minimum of 1 second could be fine and be able to set a maximum of 10 minutes too if possible.
In which case you need to report an alarm in less than 1 second ? If you have 10 meters, it is quite impossible to scan a PIR in the list in less than 1Sec.
Best Regards
Eric
