Unable to get frequent refresh interval - Xiaomi LYWSD03MMC
Yes of course. It works by default like this.
That’s what I thought originally but this is what I’m getting once I rename the gateway/topic as per my other esp32 (OMG_BLE1/OMG_BLE1):
Once I rename it back to OMG_BLE2/OMG_BLE2 all is good.
The logic that we use to have in the controllers for this, is to have them subscribe to +/+/112233445566 , 112233445566 being the sensor id.
This way you can respect the MQTT topic structure and easily identify your gateways.
Currently the gateway name is used as the client id, so having a duplicated cliebt id is not mqtt compliant and generate the disconnections.
I may change this to take the mac as the client id.
So if I get this right, with the current payload structure
it is not possible to publish to the same topic with multiple esp32 unless you change clientid to mac address / future release?
Edit: guess I could manually create a sensor with the +/+/112233445566 structure…
That’s where the difference resides, Tasmota can consolidate all sensor data to a common topic:
We never needed this before as the programs using mqtt can subscribe to a wildcard.
The issue with this approach is that you are not taking advantage of the mqtt topic structure to have a meaning.
What program are you using to get the data?
Yes totally agree, that’s why I said I could manually create a wildcard sensor in my previous post.
Will try it later and see how it goes. I’m using HA.
The consolidated tasmota approach for BLE is not default, just an option. Can be useful if all ESP32 serve the same/single purpose. This only applies to BLE sensor data so the rest of the MQTT structure remains intact so you can still distinguish every ESP32/other features.
With HA if you use auto discovery you should not have to take care of this.
The gateway will create a device and its entities automatically with the wildcards.
The devices created are avalaible into the settings.
You are right, for some reason I thought automatically created sensors were associated to a specific device which is not the case. So if I have 2 ESP32 receiving the same sensor data, it all gets published to the same HA sensor, right? Meaning that the more ESP32 I have receiving/broadcasting the signal, the more precise the resolution should be (with potential impact on battery life for active devices I guess) ?
That is correct, but I still don’t feel you above chart is good enough for a
  "interval": 1000,
  "scanduration": 5000,
and you shouldn’t have to restort to setting up multiple ESP32 gateways to receive more frequent updates. With the above setting you really should see a message, and therefore value update, every 6 seconds.
Did you ever watch the message interval in the MQTT Explorer History? What is the interval there, or might you get different undecoded messages in between?
Also feel the same. Will check and get back to you shortly.
it just seems to publish randomly, anywhere between 5 and 50 seconds
Meanwhile, tasmota captures every 1-9 seconds.
Also confirmed that only one ESP32 publishes (one for OMG, one for Tasmota)
OMG
02/03/2024 11:34:11 AM(-2.6 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-78,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.21,"tempf":75.578,"hum":32.34,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:34:06 AM(-5.12 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-70,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.21,"tempf":75.578,"hum":32.34,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:33:56 AM(-9.83 seconds)
02/03/2024 11:33:33 AM(-22.7 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.04,"tempf":75.272,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:33:28 AM(-4.97 seconds)
02/03/2024 11:32:51 AM(-37.42 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.92,"tempf":75.056,"hum":32.12,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:32:26 AM(-24.96 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-78,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.1,"tempf":75.38,"hum":32.31,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:58 AM(-27.72 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.32,"tempf":75.776,"hum":31.78,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:51 AM(-7.51 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.96,"tempf":75.128,"hum":31.82,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:41 AM(-10.02 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":31.87,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:33 AM(-7.53 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-71,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.19,"tempf":75.542,"hum":32.33,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:13 AM(-19.79 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-71,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.07,"tempf":75.326,"hum":32.32,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:31:06 AM(-7.68 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.07,"tempf":75.326,"hum":32.32,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:30:43 AM(-22.42 seconds)
{"id":"A4:C1:38:2A:F7:16","name":"ATC_2AF716","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:30:33 AM(-10.12 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:30:23 AM(-10.04 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.08,"tempf":75.344,"hum":32.13,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:29:31 AM(-52.49 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.19,"tempf":75.542,"hum":32.33,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:29:21 AM(-10.03 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-78,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.31,"tempf":75.758,"hum":32.1,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:29:08 AM(-12.54 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.14,"tempf":75.452,"hum":32.14,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:29:03 AM(-4.95 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.14,"tempf":75.452,"hum":32.14,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:28:51 AM(-12.56 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-78,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.28,"tempf":75.704,"hum":32.45,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:28:46 AM(-5.03 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.28,"tempf":75.704,"hum":32.45,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:28:28 AM(-17.52 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-77,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.25,"tempf":75.65,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:28:23 AM(-5.01 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-77,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24,"tempf":75.2,"hum":32.17,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:27:46 AM(-37.53 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.98,"tempf":75.164,"hum":32.46,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:27:28 AM(-17.5 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.04,"tempf":75.272,"hum":32.08,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:26:56 AM(-32.47 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.95,"tempf":75.11,"hum":32.13,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:26:38 AM(-17.3 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-82,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.94,"tempf":75.092,"hum":32.55,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:26:28 AM(-10.23 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.09,"tempf":75.362,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:26:21 AM(-7.46 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.25,"tempf":75.65,"hum":32.07,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:26:03 AM(-17.6 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.25,"tempf":75.65,"hum":32.18,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:53 AM(-10 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-70,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.25,"tempf":75.65,"hum":32.18,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:43 AM(-9.96 seconds)
{"id":"A4:C1:38:2A:F7:16","name":"ATC_2AF716","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.08,"tempf":75.344,"hum":32.13,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:41 AM(-2.5 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.08,"tempf":75.344,"hum":32.13,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:31 AM(-9.99 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-77,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.21,"tempf":75.578,"hum":32.19,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:25 AM(-5.09 seconds)
02/03/2024 11:25:23 AM(-2.4 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":32.36,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:16 AM(-7.57 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-77,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":32.36,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:25:08 AM(-7.33 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-82,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.15,"tempf":75.47,"hum":32.09,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:24:28 AM(-40.23 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.14,"tempf":75.452,"hum":32.09,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:24:08 AM(-20.03 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-77,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.26,"tempf":75.668,"hum":32.15,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:23:18 AM(-49.89 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.74,"tempf":76.532,"hum":32.57,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:23:08 AM(-10.06 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.13,"tempf":75.434,"hum":31.96,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:22:55 AM(-12.57 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.25,"tempf":75.65,"hum":32.08,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:22:48 AM(-7.21 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.18,"tempf":75.524,"hum":32.42,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:22:40 AM(-7.82 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.14,"tempf":75.452,"hum":31.76,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:22:28 AM(-12.51 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.05,"tempf":75.29,"hum":32.36,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:22:00 AM(-27.39 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-82,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.08,"tempf":75.344,"hum":32.13,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:21:43 AM(-17.7 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24,"tempf":75.2,"hum":32.41,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:21:33 AM(-9.94 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-70,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.26,"tempf":75.668,"hum":32.15,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:21:25 AM(-7.55 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-76,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.26,"tempf":75.668,"hum":32.15,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:21:13 AM(-12.37 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-71,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.81,"tempf":74.858,"hum":32.29,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:21:08 AM(-5.15 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-79,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.81,"tempf":74.858,"hum":32.29,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:20:58 AM(-10 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-81,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.92,"tempf":75.056,"hum":32.47,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:20:48 AM(-9.91 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-75,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":23.94,"tempf":75.092,"hum":32.11,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:20:38 AM(-10.08 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-80,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.08,"tempf":75.344,"hum":32.31,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:20:18 AM(-19.72 seconds)
{"id":"A4:C1:38:2A:F7:16","rssi":-70,"brand":"Xiaomi","model":"TH Sensor","model_id":"LYWSD03MMC/MJWSD05MMC_PVVX","type":"THB","tempc":24.2,"tempf":75.56,"hum":32.19,"batt":100,"volt":2.999,"mac":"A4:C1:38:2A:F7:16"}
02/03/2024 11:20:03 AM(-15.32 seconds)
Tasmota
 {"Time":"2024-02-03T11:36:49","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:36:40 AM(-9.03 seconds)
{"Time":"2024-02-03T11:36:40","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:36:34 AM(-5.93 seconds)
{"Time":"2024-02-03T11:36:34","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:36:34 AM(-0.9 seconds)
02/03/2024 11:36:25 AM(-8.7 seconds)
{"Time":"2024-02-03T11:36:25","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:36:24 AM(-1.15 seconds)
{"Time":"2024-02-03T11:36:23","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:36:24 AM(-0.13 seconds)
{"Time":"2024-02-03T11:36:24","mac":"a4c1382af716","Temperature":23.7,"Humidity":31.7,"DewPoint":5.8,"Btn":0,"Battery":100,"RSSI":-83,"TempUnit":"C"}
02/03/2024 11:36:21 AM(-2.51 seconds)
{"Time":"2024-02-03T11:36:21","mac":"a4c1382af716","Temperature":24.4,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:36:19 AM(-1.64 seconds)
{"Time":"2024-02-03T11:36:19","mac":"a4c1382af716","Temperature":24.4,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:36:19 AM(-0.87 seconds)
02/03/2024 11:36:11 AM(-7.52 seconds)
{"Time":"2024-02-03T11:36:11","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.0,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:36:10 AM(-1.18 seconds)
{"Time":"2024-02-03T11:36:10","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.3,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:36:04 AM(-5.4 seconds)
{"Time":"2024-02-03T11:36:04","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.1,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:55 AM(-9.59 seconds)
{"Time":"2024-02-03T11:35:55","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.3,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:35:51 AM(-3.82 seconds)
{"Time":"2024-02-03T11:35:51","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.3,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:35:49 AM(-1.63 seconds)
{"Time":"2024-02-03T11:35:49","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.1,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:40 AM(-9.57 seconds)
{"Time":"2024-02-03T11:35:40","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.1,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-85,"TempUnit":"C"}
02/03/2024 11:35:38 AM(-1.35 seconds)
{"Time":"2024-02-03T11:35:38","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.1,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-85,"TempUnit":"C"}
02/03/2024 11:35:38 AM(-0.04 seconds)
{"Time":"2024-02-03T11:35:38","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.1,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:35 AM(-3.89 seconds)
{"Time":"2024-02-03T11:35:34","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.3,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:28 AM(-6.12 seconds)
{"Time":"2024-02-03T11:35:28","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.3,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:25 AM(-3.58 seconds)
{"Time":"2024-02-03T11:35:25","mac":"a4c1382af716","Temperature":24.3,"Humidity":32.1,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:35:21 AM(-3.9 seconds)
{"Time":"2024-02-03T11:35:21","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.3,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-83,"TempUnit":"C"}
02/03/2024 11:35:19 AM(-1.54 seconds)
{"Time":"2024-02-03T11:35:19","mac":"a4c1382af716","Temperature":24.3,"Humidity":32.1,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:11 AM(-8.4 seconds)
{"Time":"2024-02-03T11:35:11","mac":"a4c1382af716","Temperature":24.3,"Humidity":32.1,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:35:10 AM(-1.14 seconds)
{"Time":"2024-02-03T11:35:10","mac":"a4c1382af716","Temperature":24.3,"Humidity":32.1,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:35:06 AM(-3.85 seconds)
{"Time":"2024-02-03T11:35:06","mac":"a4c1382af716","Temperature":24.3,"Humidity":32.1,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:35:05 AM(-0.93 seconds)
{"Time":"2024-02-03T11:35:04","mac":"a4c1382af716","Temperature":24.5,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:35:01 AM(-4.07 seconds)
{"Time":"2024-02-03T11:35:01","mac":"a4c1382af716","Temperature":24.5,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:35:01 AM(-0.04 seconds)
{"Time":"2024-02-03T11:35:01","mac":"a4c1382af716","Temperature":24.5,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:34:58 AM(-2.56 seconds)
{"Time":"2024-02-03T11:34:58","mac":"a4c1382af716","Temperature":24.5,"Humidity":32.1,"DewPoint":6.7,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:34:55 AM(-3.57 seconds)
{"Time":"2024-02-03T11:34:55","mac":"a4c1382af716","Temperature":24.2,"Humidity":31.9,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:34:51 AM(-3.86 seconds)
{"Time":"2024-02-03T11:34:51","mac":"a4c1382af716","Temperature":24.2,"Humidity":31.9,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:34:49 AM(-1.57 seconds)
{"Time":"2024-02-03T11:34:49","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.4,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:34:44 AM(-5.9 seconds)
{"Time":"2024-02-03T11:34:43","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:34:40 AM(-3.7 seconds)
{"Time":"2024-02-03T11:34:40","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-88,"TempUnit":"C"}
02/03/2024 11:34:36 AM(-3.78 seconds)
{"Time":"2024-02-03T11:34:36","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-88,"TempUnit":"C"}
02/03/2024 11:34:35 AM(-1.53 seconds)
{"Time":"2024-02-03T11:34:34","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.4,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:34:31 AM(-3.53 seconds)
{"Time":"2024-02-03T11:34:31","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.4,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:34:26 AM(-4.96 seconds)
{"Time":"2024-02-03T11:34:26","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.4,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:34:25 AM(-0.98 seconds)
{"Time":"2024-02-03T11:34:25","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:34:24 AM(-1.51 seconds)
{"Time":"2024-02-03T11:34:23","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.4,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:34:19 AM(-4.1 seconds)
{"Time":"2024-02-03T11:34:19","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.0,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:34:18 AM(-1.03 seconds)
{"Time":"2024-02-03T11:34:18","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.0,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:34:11 AM(-7.53 seconds)
{"Time":"2024-02-03T11:34:11","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:34:10 AM(-1.03 seconds)
{"Time":"2024-02-03T11:34:10","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:34:08 AM(-1.46 seconds)
{"Time":"2024-02-03T11:34:08","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:34:06 AM(-2.44 seconds)
{"Time":"2024-02-03T11:34:06","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:34:04 AM(-1.53 seconds)
{"Time":"2024-02-03T11:34:04","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:58 AM(-5.96 seconds)
{"Time":"2024-02-03T11:33:58","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-87,"TempUnit":"C"}
02/03/2024 11:33:56 AM(-2.56 seconds)
{"Time":"2024-02-03T11:33:56","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.3,"DewPoint":6.6,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:55 AM(-0.92 seconds)
{"Time":"2024-02-03T11:33:55","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.1,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-88,"TempUnit":"C"}
02/03/2024 11:33:49 AM(-5.57 seconds)
{"Time":"2024-02-03T11:33:49","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:33:43 AM(-5.97 seconds)
{"Time":"2024-02-03T11:33:43","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:33:40 AM(-3.15 seconds)
{"Time":"2024-02-03T11:33:40","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.1,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-88,"TempUnit":"C"}
02/03/2024 11:33:34 AM(-5.87 seconds)
{"Time":"2024-02-03T11:33:34","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:33 AM(-0.93 seconds)
{"Time":"2024-02-03T11:33:33","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.1,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-88,"TempUnit":"C"}
02/03/2024 11:33:31 AM(-2.52 seconds)
{"Time":"2024-02-03T11:33:31","mac":"a4c1382af716","Temperature":24.0,"Humidity":32.1,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:33:25 AM(-6.15 seconds)
{"Time":"2024-02-03T11:33:25","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:33:19 AM(-5.41 seconds)
{"Time":"2024-02-03T11:33:19","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:18 AM(-1.02 seconds)
{"Time":"2024-02-03T11:33:18","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:33:16 AM(-2.51 seconds)
{"Time":"2024-02-03T11:33:16","mac":"a4c1382af716","Temperature":24.2,"Humidity":32.1,"DewPoint":6.5,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:10 AM(-6.09 seconds)
{"Time":"2024-02-03T11:33:10","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:33:08 AM(-1.36 seconds)
{"Time":"2024-02-03T11:33:08","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:33:06 AM(-2.56 seconds)
{"Time":"2024-02-03T11:33:06","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:33:04 AM(-1.43 seconds)
{"Time":"2024-02-03T11:33:04","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:32:55 AM(-9.31 seconds)
{"Time":"2024-02-03T11:32:55","mac":"a4c1382af716","Temperature":24.3,"Humidity":31.8,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:32:49 AM(-5.64 seconds)
{"Time":"2024-02-03T11:32:49","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:32:43 AM(-6.21 seconds)
{"Time":"2024-02-03T11:32:43","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.1,"DewPoint":6.2,"Btn":0,"Battery":100,"RSSI":-81,"TempUnit":"C"}
02/03/2024 11:32:40 AM(-3.1 seconds)
{"Time":"2024-02-03T11:32:40","mac":"a4c1382af716","Temperature":24.3,"Humidity":31.8,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:32:38 AM(-1.84 seconds)
{"Time":"2024-02-03T11:32:38","mac":"a4c1382af716","Temperature":24.1,"Humidity":32.0,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:32:34 AM(-3.89 seconds)
{"Time":"2024-02-03T11:32:34","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.4,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:32:25 AM(-9.51 seconds)
{"Time":"2024-02-03T11:32:25","mac":"a4c1382af716","Temperature":24.3,"Humidity":31.8,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:32:19 AM(-5.51 seconds)
{"Time":"2024-02-03T11:32:19","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.4,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:32:13 AM(-6.08 seconds)
{"Time":"2024-02-03T11:32:13","mac":"a4c1382af716","Temperature":23.9,"Humidity":32.4,"DewPoint":6.3,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:32:10 AM(-3.54 seconds)
{"Time":"2024-02-03T11:32:10","mac":"a4c1382af716","Temperature":24.3,"Humidity":31.8,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:32:04 AM(-5.35 seconds)
{"Time":"2024-02-03T11:32:04","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:31:58 AM(-6.1 seconds)
{"Time":"2024-02-03T11:31:58","mac":"a4c1382af716","Temperature":24.3,"Humidity":31.8,"DewPoint":6.4,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:31:55 AM(-3.49 seconds)
{"Time":"2024-02-03T11:31:55","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:31:51 AM(-4.12 seconds)
{"Time":"2024-02-03T11:31:51","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-82,"TempUnit":"C"}
02/03/2024 11:31:49 AM(-1.3 seconds)
{"Time":"2024-02-03T11:31:49","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:31:48 AM(-1.15 seconds)
{"Time":"2024-02-03T11:31:48","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-86,"TempUnit":"C"}
02/03/2024 11:31:48 AM(-0 seconds)
{"Time":"2024-02-03T11:31:48","mac":"a4c1382af716","Temperature":24.0,"Humidity":31.8,"DewPoint":6.1,"Btn":0,"Battery":100,"RSSI":-84,"TempUnit":"C"}
02/03/2024 11:31:46 AM(-2.55 seconds)
Yes, so by adjusting interval even lower, to something like 100 and scanduration to 1000 or 2000 you’ll likely get a similar result to Tasmota.
The fact remains though that there must be some other issue with the actual PVVX firmware settings when being installed, as both OMG and Tasmota do not have constant regular readings, but vary quite substantially in their publishing intervals. These readings should be very regular though, so looking at the actual firmware settings would also be good.
So the LYWSD03MMC is a passive device, right ? Zero influence from intervalacts and intervalcnct?
Here are the results with interval 100 and scanduration 2000
And pvvx settings
I really don’t know anything about the Telink Flasher setting, as I do not have a LYWSD03MMC myself, but regardless of the different receiving intervals, both OMG and Tasmota show unexpected very irregular receptions, which is weird.
If I set my OMG BLE gateway to
  "interval": 1000,
for example and monitor any of my BLE thermometers and other devices, they all do come in reliably every 6 seconds.
Are you sure you haven’t got a WiFi access point/router or any other 2.4GHz interference source close by to create these irregular receptions?
And are you sure Tasmota is not getting the values by connection, as from the little I know about Tasmota the BLE broadcast reception interval you stated above with
TelePeriod "10"
should mean also only every 10 seconds, which obviously is also not the case from your interval monitoring above.
Something somewhere does not seem quite right.
