Xiaomi Mijia LYWSD03MMC ESP32 support
You can now try an easiest way by flashing directly from the web : (Option 1) Upload from the web | OpenMQTTGateway v1.7.0
  1. Just connect your board, select esp32dev-ble or esp32dev-ble-cont (if you want continuous scanning)
  2. Keep “Erase flash”
  3. Click on Install
  4. Press the boot button (optional)
  5. Select the COM port
  6. Click on connect
  7. Release the boot button (optional)
  8. Erase process should start followed by the flashing
After you should see a WIFI access point so as to enter your configuration
Yey! worked first time. Thanks for the prompt response.
