Summary: recently reflashed lilygo with v1.7, Freq set to 433.92 and now no devices found.
Hi, I was previously running 1.6 which was successfully picking up devices. Devices are 433MHz in this country. I have a temp sensor that encodes with FSK so was interested to try 1.7
I see you can change active freq in the 1.7 web interface (default flash was 915 from memory) so I have set to 433.92MHz which I’m pretty sure it was in the previous setup (also tried 433.0MHz). Previously there were 5-50 items regularly reporting. Now I get no devices at all reported to MQTT.
{“uptime”:72611,“version”:“v1.7.0”,“disc”:false,“ohdisc”:false,“env”:“lilygo-rtl_433-fsk”,“freemem”:120604,“mqttp”:“1883”,“mqtts”:false,“msgprc”:1816,“msgblck”:0,“maxq”:4,“minmem”:54288,“tempc”:50,“freestck”:2224,“eth”:false,“rssi”:-44,“SSID”:“redacted”,“BSSID”:“redacted”,“ip”:“redacted”,“mac”:“redacted”,“modules”:[“LilyGo_SSD1306”,“WebUI”,“rtl_433”]}
