433 mhz ASK protocol?
Thanks. While searching it mentions the CC1101 decodes the protocol on chip and the RTL library isn’t needed, but you still had to configure the chip to use the desired protocol. I’ll do a deeper dive so I can understand what it all does. Thanks for the pointers. Helps a lot
