915mhz lilygo scm/scm+ readings
So I was able to get the lilygo-rtl_433 firmware running on the lora32 915mh version, and switch the frequency to 915mhz.
But then I saw that despite supporting OOK decoding, the OMG docs don’t mention the scm/scm+ decoders.
Is there an update in the works or a technical limitation? If not I could maybe try my hand at a PR, but my C is a bit rusty…
