Using the Ardunio IDE I get the best details, more than I see in Home Assistant HiveMQ…
I think my true struggle is how to actually send a message to OMG?
From Hive MQ after connection,
for Topic I enter
home/OpenMQTTGateway/commands/MQTTtoIR
and for message to OMG I put
-m '{"value":551489775}'
but I see no action?
I also have the IDE environment & MQTT Dash if sending from those environments is better but I am assuming my command is not quite right?
This is from V92 but I can try V93 if need be…
WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] AutoConnect: SUCCESS
*WM: [1] STA IP Address: 192.168.1.225
connected…yeey
saving config
{“mqtt_server”:“192.168.1.219”,“mqtt_port”:“1883”,“mqtt_user”:“MOSQTO”,“mqtt_pass”:"*****"}*WM: [3] freeing allocated params!
*WM: [3] unloading
OpenMQTTGateway mac:
84:F3:EB:5B:04:F1
OpenMQTTGateway ip:
192.168.1.225
1883
192.168.1.219
IR_EMITTER_PIN
16
IR_RECEIVER_PIN
2
ZgatewayIR setup done
MQTT_MAX_PACKET_SIZE
1024
Setup OpenMQTTGateway end
client disconnected
MQTT connection…
failure_number
1
failed, rc=
-4
try again in 5s
MQTT connection…
Connected to broker
00:26:38.132 -> Uptime (s)
00:26:38.132 -> 120
00:26:38.132 -> omgStatusDiscovery
00:26:38.132 -> Pub json into:
00:26:38.132 -> homeassistant/binary_sensor/84F3EB5B04F1/config
00:26:38.132 -> {“stat_t”:“home/OpenMQTTGateway_ESP8266_IR/LWT”,“name”:“OpenMQTTGateway_ESP8266_IR”,“uniq_id”:“84F3EB5B04F1”,“dev_cla”:“connectivity”,“pl_on”:“online”,“pl_off”:“offline”,“pl_avail”:“online”,“pl_not_avail”:“offline”,“device”:{“name”:“OpenMQTTGateway_ESP8266_IR”,“manufacturer”:“OMG_community”,“sw_version”:“0.9.2”,“identifiers”:[“84F3EB5B04F1”]}}
00:26:38.132 -> gatewayIRDiscovery
00:26:38.132 -> CreateDiscoverySensor
00:26:38.179 -> homeassistant/sensor/84F3EB5B04F1gatewayIR/config
00:26:38.179 -> {“stat_t”:“home/OpenMQTTGateway_ESP8266_IR/IRtoMQTT”,“name”:“gatewayIR”,“uniq_id”:“84F3EB5B04F1gatewayIR”,“val_tpl”:"{{ value_json.value }}",“device”:{“name”:“OpenMQTTGateway_ESP8266_IR”,“manufacturer”:“OMG_community”,“sw_version”:“0.9.2”,“identifiers”:[“84F3EB5B04F1”]}}
00:26:38.179 -> {“uptime”:120,“freeMem”:37800,“rssi”:-58,“SSID”:“BMF”,“ip”:“192.168.1.225”,“mac”:“84:F3:EB:5B:04:F1”,“modules”:“IRHADiscovery”}
00:28:38.132 -> Uptime (s)
00:28:38.132 -> 240
