Adding device support?
I recently installed V1.6 of OpenMQTTGateway onto to a LilyGo Lora 433 ESP32 board and whilst it seems to work and seems to ‘see’ (hear?) loads of RF devices, it doesn’t see my Inkbird-ITH20R temp / humidity sensors?
I know they are working (2 x freezer 1 x fridge) as rtl_433 running on Home Assistant can see them and display the readings on my dashboard.
It was suggested that they had to remove some devices to get it all on the ESP32 so is it easy to remove some devices I’m not interested in and add things I am please?
I’m more an electronics / hardware guy so any coding would have to be very easy. :wink:
The Inkbird uses FSK modulation, and will need a custom build of OpenMQTTGateway to enable reception of FSK modulated signals.
Also I do not have an Inkbird device within my personal collection, so can not confirm that it is functional
Thanks very much for the reply and information.
Do I understand it correctly and that OpenMQTTGateway uses some of the code from rtl_433? If so, my Inkbird 433 sensors are seen by that integration ok so if I could just have support for them, that would be all I would need?
I have OMG V1.7 running in FSK mode. My TPMS Jansite Solar sensors are received by OMG, but the ITH-20R does not appear.
Has anybody successfully running that sensor?
Let me ask again:
Could anyone successfully read from the INKBIRD ITH-20R using OMG with FSK activated?
I would appreciate any hints!
Exactly these Inkbirds are listed in the supported devices (#35) but I also cannot decode the data from them. There is a counter increasing in MQTT (guess it’s pulse count it something like that).
Do you think we have to compile a personal version to include this sensor? Would really appreciate if somebody could give a hint…
Not sure I follow you, where is the ITH-20R listed as supported by Theengs or OpenMQTTGateway?
Let me find this again - i lost the page, but it’s listed under FSK decoders.
It is listed in the readme of rtl_433_ESP, so it should run with OMG.
FSK Signal Device Decoders
Registering protocol [0] "Ambient Weather WH31E Thermo-Hygrometer Sensor, EcoWitt WH40 rain gauge"
Registering protocol [2] "TBH weather sensor"
Registering protocol [3] "Badger ORION water meter, 100kbps (-f 916.45M -s 1200k)"
Registering protocol [4] "Bresser Weather Center 5-in-1"
Registering protocol [5] "Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A"
Registering protocol [6] "Bresser Weather Center 7-in-1"
Registering protocol [7] "Cavius smoke, heat and water detector"
Registering protocol [9] "CurrentCost Current Sensor"
Registering protocol [10] "Danfoss CFR Thermostat"
Registering protocol [11] "DirecTV RC66RX Remote Control"
Registering protocol [12] "EcoDHOME Smart Socket and MCEE Solar monitor"
Registering protocol [13] "Efergy e2 classic"
Registering protocol [14] "Efergy Optical"
Registering protocol [15] "Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor"
Registering protocol [16] "emonTx OpenEnergyMonitor"
Registering protocol [17] "ESIC EMT7110 power meter"
Registering protocol [18] "Fine Offset Electronics, WH25, WH32B, WH24, WH65B, HP1000, Misol WS2320 Temperature/Humidity/Pressure Sensor"
Registering protocol [19] "Fine Offset Electronics/ECOWITT WH51, SwitchDoc Labs SM23 Soil Moisture Sensor"
Registering protocol [20] "Fine Offset Electronics WH1080/WH3080 Weather Station (FSK)"
Registering protocol [21] "Ambient Weather WH31L (FineOffset WH57) Lightning-Strike sensor"
Registering protocol [22] "Fine Offset Electronics WH45 air quality sensor"
Registering protocol [23] "Fine Offset Electronics WN34 temperature sensor"
Registering protocol [24] "Fine Offset Electronics WS80 weather station"
Registering protocol [25] "Flowis flow meters"
Registering protocol [26] "GE Color Effects"
Registering protocol [27] "GEO minim+ energy monitor"
Registering protocol [28] "Microchip HCS200/HCS300 KeeLoq Hopping Encoder based remotes (FSK)"
Registering protocol [29] "Holman Industries iWeather WS5029 weather station (newer PCM)"
Registering protocol [30] "Holman Industries iWeather WS5029 weather station (older PWM)"
Registering protocol [32] "Honeywell CM921 Wireless Programmable Room Thermostat"
Registering protocol [33] "Honeywell ActivLink, Wireless Doorbell (FSK)"
Registering protocol [34] "IKEA Sparsnas Energy Meter Monitor"
Registering protocol [35] "Inkbird ITH-20R temperature humidity sensor"
Registering protocol [36] "Insteon"
Registering protocol [37] "LaCrosse Technology View LTV-WSDTH01 Breeze Pro Wind Sensor"
Registering protocol [38] "LaCrosse Technology View LTV-R1, LTV-R3 Rainfall Gauge, LTV-W1/W2 Wind Sensor"
Registering protocol [39] "LaCrosse Technology View LTV-TH Thermo/Hygro Sensor"
Registering protocol [40] "LaCrosse TX31U-IT, The Weather Channel WS-1910TWC-IT"
Registering protocol [41] "LaCrosse TX34-IT rain gauge"
Registering protocol [42] "LaCrosse TX29IT, TFA Dostmann 30.3159.IT Temperature sensor"
Registering protocol [43] "LaCrosse TX35DTH-IT, TFA Dostmann 30.3155 Temperature/Humidity sensor"
Registering protocol [44] "LaCrosse Technology View LTV-WR1 Multi Sensor"
Registering protocol [45] "Wireless M-Bus, Mode C&T, 100kbps (-f 868.95M -s 1200k)"
Registering protocol [46] "Wireless M-Bus, Mode T, 32.768kbps (-f 868.3M -s 1000k)"
Registering protocol [47] "Wireless M-Bus, Mode S, 32.768kbps (-f 868.3M -s 1000k)"
Registering protocol [50] "Marlec Solar iBoost+ sensors"
Registering protocol [51] "Maverick XR-30 BBQ Sensor"
Registering protocol [52] "Oil Ultrasonic SMART FSK"
Registering protocol [53] "Oil Ultrasonic STANDARD FSK"
Registering protocol [54] "Watchman Sonic / Apollo Ultrasonic / Beckett Rocket oil tank monitor"
Registering protocol [55] "Watchman Sonic Advanced / Plus"
Registering protocol [56] "RojaFlex shutter and remote devices"
Registering protocol [57] "Sharp SPC775 weather station"
Registering protocol [58] "SimpliSafe Gen 3 Home Security System"
Registering protocol [59] "Somfy io-homecontrol"
Registering protocol [60] "SRSmith Pool Light Remote Control SRS-2C-TX (-f 915M)"
Registering protocol [61] "Steelmate TPMS"
Registering protocol [62] "TFA Dostmann 14.1504.V2 Radio-controlled grill and meat thermometer"
Registering protocol [63] "TFA Dostmann 30.3196 T/H outdoor sensor"
Registering protocol [64] "TFA Marbella Pool Thermometer"
Registering protocol [65] "Abarth 124 Spider TPMS"
Registering protocol [66] "AVE TPMS"
Registering protocol [67] "Citroen TPMS"
Registering protocol [68] "Elantra2012 TPMS"
Registering protocol [69] "Ford TPMS"
Registering protocol [70] "Hyundai TPMS (VDO)"
Registering protocol [72] "Jansite TPMS Model Solar"
Registering protocol [73] "Kia TPMS (-s 1000k)"
Registering protocol [74] "PMV-107J (Toyota) TPMS"
Registering protocol [75] "Porsche Boxster/Cayman TPMS"
Registering protocol [76] "Renault TPMS"
Registering protocol [77] "Renault 0435R TPMS"
Registering protocol [78] "Toyota TPMS"
Registering protocol [79] "Unbranded SolarTPMS for trucks
One is here, but just for the rtl_433 library:
  • but there was another list…
Ah, it says “trial port to use for OMG”
(I must say, i am not a programmer)
Does this just mean that the library is able to decode this thing but it was not yet implemented to OMG?
Oh, and it’s says CC1101 transceiver but my lilygo has SX127x…
Hmmm… Hopefully somebody can try it - i would, but i am not sure if i am able to compile this stuff …
FSK support is in beta, if one wants to try one device I would suggest to:
0 - Use the dev version of OMG for testing
1 - pickup the frequency and parameters used by RTL_433 for this device
2 - configure OMG with the web portal with these parameters, follow the reception on the web serial monitor
3 - if it does not work try to change the parameter and see if you catch something
4 - report your findings here
Thanks for the suggestions - let’s see when i can find the time :stuck_out_tongue_winking_eye:
Today I’ve got managed to compile the package from the development tree with some compiler options for debugging. See my_env.ini:
[env:lilygo-rtl_433-fsk-cbtest-433]
board = ttgo-lora32-v21
  ${com-esp32.lib_deps}
  ${libraries.ssd1306}
  ${libraries.rtl_433_ESP}
  ${com-esp32.build_flags}
  '-DGateway_Name="OMG_lilygo_rtl_433_ESP"'
  '-DOOK_MODULATION=false' ; FSK modulation activated
  ;-DRF_FREQUENCY=915'
  ;-DRF_FREQUENCY=868.300'
  '-DRF_FREQUENCY=433.9'
  '-DLOG_LEVEL=LOG_LEVEL_TRACE'
; *** rtl_433_ESP Options ***
  '-DRTL_DEBUG=4'           ; rtl_433 verbose mode
  '-DRTL_VERBOSE=35'          ; protocol
  ;'-DRAW_SIGNAL_DEBUG=true'   ; display raw received messages
  ;'-DMEMORY_DEBUG=true'   ; display memory usage information
  ;'-DDEMOD_DEBUG=true'  ; display signal debug info
  ;'-DMY_DEVICES=true'		; subset of devices
;  '-DPUBLISH_UNPARSED=true'   ; publish unparsed signal details
;  '-DRSSI_THRESHOLD=12'         ; Apply a delta of 12 (default 9)
;  '-DOOK_FIXED_THRESHOLD=0x50'  ; Inital OOK Threhold - Only for SX127X (default 5A)
  '-DAVERAGE_RSSI=5000'     ; Display RSSI floor ( Average of 5000 samples )
  '-DSIGNAL_RSSI=true'             ; Display during signal receive
  '-DRF_MODULE_INIT_STATUS=true'
  ;-DRTL_ANALYZER=true'
  '-DRTL_ANALYZE=35'
  '-DRTL_VERBOSE=35'
  '-DRTL_433_DISCOVERY_LOGGING=true'
  '-DZgatewayRTL_433="rtl_433"'
  '-DZradioSX127x="SX127x"'
  '-DOMG_VERSION="1.8 cbtest_fsk_433"'
;  '-DLOG_TO_OLED=true'         ; Enable log to OLED
;  '-DJSON_TO_OLED=true'
;  '-DDISPLAY_BRIGHTNESS=80'
;  '-DDISPLAY_METRIC=false'
custom_description = 433 Mhz with RTL_433 debugging for ITH20R with FSK modulation (beta)
There was absolutely no valid reception and decoding of my ITH-20R sensor. But some lines regarding that sensor appeared. Similar lines appear for other protocols, too.
See an excerpt of the putty log file:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.12.07 20:56:32 =~=~=~=~=~=~=~=~=~=~=~=
ets Jun  8 2016 00:22:57
configsip: 188777542, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13192
load:0x40080400,len:3028
entry 0x400805e4
N:
N: Config mqtt unchanged, currently: true
N: Config serial unchanged, currently: false
N: Config offline unchanged, currently: false
N: Config disc unchanged, currently: true
N: Config ohdisc changed to: true
N: Config powermode unchanged, currently: false
N: SYS config loaded
N: SSD1306 config initialised
N: No SSD1306 config to load
T: Setup SSD1306 Display
T: ZdisplaySSD1306 command topic: /commands/MQTTtoSSD1306/config
T: ZdisplaySSD1306 log-oled: false
T: ZdisplaySSD1306 json-oled: false
T: ZdisplaySSD1306 DISPLAY_PAGE_INTERVAL: 3
T: ZdisplaySSD1306 DISPLAY_IDLE_LOGO: true
T: ZdisplaySSD1306 DISPLAY_FLIP: true
N: Setup SSD1306 Display end
N: OpenMQTTGateway Version: 1.8 cbtest_fsk_433
T: mounting FS...
T: mounted file system
T: reading config file
T: opened config file
T:
parsed json, size: 1631
N: OTA server cert hash: 02118cbaf5cc02748398d93ecdb0ef2a444c37358a617bfb2206dfe351dc7cf2
N: Config loaded from flash
T: OpenMQTTGateway mac: D4:D4:DA:82:ED:2C
T: OpenMQTTGateway ip: 192.168.0.25
T: OpenMQTTGateway index 0
T: OpenMQTTGateway mqtt topic: OMG/
T: OpenMQTTGateway mqtt discovery prefix: homeassistant
T: OpenMQTTGateway gateway name: OMG_lilygo_rtl_433_ESP
T: OpenMQTTGateway mqtt server: ds218plus
T: OpenMQTTGateway mqtt port: 1883
T: OpenMQTTGateway mqtt user:
T: OpenMQTTGateway secure connection: false
T: OpenMQTTGateway validate cert: false
N: No WebUI config to load
T: [WebUI] displayMetric true
T: [WebUI] WebUI Secure true
N: OpenMQTTGateway URL: http://192.168.0.25/
N: ZwebUI setup done
T: enableActiveReceiver: 3
N: Enable RTL_433 Receiver: 433.90Mhz
Registering protocol [79] "Unbranded SolarTPMS for trucks"
----- SX127x Status -----
RegOpMode: 0x0d
RegPacketConfig1: 0x00
RegPacketConfig2: 0x00
RegBitrateMsb: 0x07
RegBitrateLsb: 0x40
RegRxBw: 0x12
RegAfcBw: 0x02
RegLna: 0x20
RegRxConfig: 0x08
RegRssiConfig: 0x00
RegDioMapping1: 0x00
----------- FSK --------------
FDEV_MSB: 0x02
FDEV_LSB: 0x8f
T: ZgatewayRTL_433 command topic: OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoRF/config
N: ZgatewayRTL_433 setup done
T: mqtt_max_payload_size: 1184
N: Offline disabled
N: OpenMQTTGateway modules: ["LilyGo_SSD1306","WebUI","rtl_433"]
N: Reconfiguring MQTT client...
T: Mqtt server: ds218plus
T: Port: 1883
N: Update check, free heap: 66584N: Using memory cert
[  8617][E][ssl_client.cpp:37] _handle_error(): [start_ssl_client():273]: (-10368) X509 - Allocation of memory failed
[  8618][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -10368
E: Error on HTTP requestN: Update check done, free heap: 62276T: No update file found on server
N: Connected to broker
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/LWT msg: online
T: omgStatusDiscovery
T: Announce Device binary_sensor on  homeassistant/binary_sensor/D4D4DA82ED2C-connectivity/config
T: Enqueue JSON
T: Queue length: 1
T: Announce Device sensor on  homeassistant/sensor/D4D4DA82ED2C-uptime/config
T: Enqueue JSON
T: Queue length: 2
T: Announce Device sensor on  homeassistant/sensor/D4D4DA82ED2C-freemem/config
T: Enqueue JSON
T: Queue length: 3
T: Announce Device sensor on  homeassistant/sensor/D4D4DA82ED2C-ip/config
T: Enqueue JSON
T: Queue length: 4
T: Announce Device switch on  homeassistant/switch/D4D4DA82ED2C-disc/config
T: Enqueue JSON
T: Queue length: 5
T: Announce Device switch on  homeassistant/switch/D4D4DA82ED2C-ohdisc/config
T: Enqueue JSON
T: Queue length: 6
T: Announce Device switch on  homeassistant/switch/D4D4DA82ED2C-onstate/config
T: Enqueue JSON
T: Queue length: 7
T: Announce Device switch on  homeassistant/switch/D4D4DA82ED2C-displayMetric/config
T: Enqueue JSON
T: Queue length: 8
T: Announce Device number on  homeassistant/number/D4D4DA82ED2C-brightness/config
T: Enqueue JSON
T: Queue length: 9
T: Announce Device sensor on  homeassistant/sensor/D4D4DA82ED2C-rssi/config
T: Enqueue JSON
T: Queue length: 10
T: Announce Device sensor on  homeassistant/sensor/D4D4DA82ED2C-tempc/config
T: Enqueue JSON
T: Queue length: 11
T: Announce Device button on  homeassistant/button/D4D4DA82ED2C-restart/config
T: Enqueue JSON
T: Queue length: 12
T: Announce Device button on  homeassistant/button/D4D4DA82ED2C-erase/config
T: Enqueue JSON
T: Queue length: 13
T: Announce Device update on  homeassistant/update/D4D4DA82ED2C-update/config
T: Enqueue JSON
T: Queue length: 14
T: MQTT Msg topic: OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/config
T: MQTTtoSYS json
N: OpenHAB discovery: true
N: SYS Config_save: {"mqtt":true,"serial":false,"offline":false,"powermode":-1,"disc":true,"ohdisc":true}, result: 85
T: Enqueue JSON
T: Queue length: 15
N: SYS json: {"uptime":10,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":55268,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":0,"msgblck":0,"msgrcv":14,"maxq":0,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-37,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":"'LilyGo_SSD1306', 'WebUI', 'rtl_433'","origin":"/SYStoMQTT"}
T: Enqueue JSON
T: Queue length: 16
N: SYS json: {"uptime":10,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":54872,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":0,"msgblck":0,"msgrcv":15,"maxq":0,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-38,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":"'LilyGo_SSD1306', 'WebUI', 'rtl_433'","origin":"/SYStoMQTT"}
T: Enqueue JSON
T: Queue length: 17
T: Enqueue JSON
T: Queue length: 18
T: Enqueue JSON
T: Queue length: 19
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/binary_sensor/D4D4DA82ED2C-connectivity/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: Connectivity","uniq_id":"D4D4DA82ED2C-connectivity","pl_on":"online","pl_off":"offline","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/sensor/D4D4DA82ED2C-uptime/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","dev_cla":"duration","unit_of_meas":"s","name":"SYS: Uptime","uniq_id":"D4D4DA82ED2C-uptime","val_tpl":"{{ value_json.uptime }}","pl_avail":"online","pl_not_avail":"offline","stat_cla":"measurement","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/sensor/D4D4DA82ED2C-freemem/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","dev_cla":"data_size","unit_of_meas":"B","name":"SYS: Free memory","uniq_id":"D4D4DA82ED2C-freemem","val_tpl":"{{ value_json.freemem }}","pl_avail":"online","pl_not_avail":"offline","stat_cla":"measurement","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/sensor/D4D4DA82ED2C-ip/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: IP","uniq_id":"D4D4DA82ED2C-ip","val_tpl":"{{ value_json.ip }}","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/switch/D4D4DA82ED2C-disc/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: Auto discovery","uniq_id":"D4D4DA82ED2C-disc","val_tpl":"{{ value_json.disc }}","pl_on":"{\"disc\":true,\"save\":true}","pl_off":"{\"disc\":false,\"save\":true}","pl_avail":"online","pl_not_avail":"offline","stat_on":true,"stat_off":false,"cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/switch/D4D4DA82ED2C-ohdisc/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: OpenHAB discovery","uniq_id":"D4D4DA82ED2C-ohdisc","val_tpl":"{{ value_json.ohdisc }}","pl_on":"{\"ohdisc\":true,\"save\":true}","pl_off":"{\"ohdisc\":false,\"save\":true}","pl_avail":"online","pl_not_avail":"offline","stat_on":true,"stat_off":false,"cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/switch/D4D4DA82ED2C-onstate/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SSD1306toMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SSD1306: Control","uniq_id":"D4D4DA82ED2C-onstate","val_tpl":"{{ value_json.onstate }}","pl_on":"{\"onstate\":true,\"save\":true}","pl_off":"{\"onstate\":false,\"save\":true}","pl_avail":"online","pl_not_avail":"offline","stat_on":true,"stat_off":false,"cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSSD1306/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/switch/D4D4DA82ED2C-displayMetric/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/WebUItoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SSD1306: Display metric","uniq_id":"D4D4DA82ED2C-displayMetric","val_tpl":"{{ value_json.displayMetric }}","pl_on":"{\"displayMetric\":true,\"save\":true}","pl_off":"{\"displayMetric\":false,\"save\":true}","pl_avail":"online","pl_not_avail":"offline","stat_on":true,"stat_off":false,"cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoWebUI/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/number/D4D4DA82ED2C-brightness/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SSD1306toMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SSD1306: Brightness","uniq_id":"D4D4DA82ED2C-brightness","val_tpl":"{{ value_json.brightness }}","cmd_tpl":"{\"brightness\":{{value}},\"save\":true}","pl_avail":"online","pl_not_avail":"offline","cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSSD1306/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/sensor/D4D4DA82ED2C-rssi/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","dev_cla":"signal_strength","unit_of_meas":"dB","name":"SYS: RSSI","uniq_id":"D4D4DA82ED2C-rssi","val_tpl":"{{ value_json.rssi }}","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/sensor/D4D4DA82ED2C-tempc/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","dev_cla":"temperature","unit_of_meas":"°C","name":"SYS: Internal temperature","uniq_id":"D4D4DA82ED2C-tempc","val_tpl":"{{ value_json.tempc  | round(1)}}","pl_avail":"online","pl_not_avail":"offline","stat_cla":"measurement","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/button/D4D4DA82ED2C-restart/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","dev_cla":"restart","name":"SYS: Restart gateway","uniq_id":"D4D4DA82ED2C-restart","pl_prs":"{\"cmd\":\"restart\"}","pl_avail":"online","pl_not_avail":"offline","cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/button/D4D4DA82ED2C-erase/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: Erase credentials","uniq_id":"D4D4DA82ED2C-erase","pl_prs":"{\"cmd\":\"erase\"}","pl_avail":"online","pl_not_avail":"offline","cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/config","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: homeassistant/update/D4D4DA82ED2C-update/config msg: {"stat_t":"OMG/OMG_lilygo_rtl_433_ESP/RLStoMQTT","avty_t":"OMG/OMG_lilygo_rtl_433_ESP/LWT","name":"SYS: Firmware Update","uniq_id":"D4D4DA82ED2C-update","pl_inst":"{\"version\":\"latest\"}","pl_avail":"online","pl_not_avail":"offline","cmd_t":"OMG/OMG_lilygo_rtl_433_ESP/commands/MQTTtoSYS/firmware_update","device":{"ids":["D4D4DA82ED2C"],"name":"OMG_lilygo_rtl_433_ESP","mdl":"[\"LilyGo_SSD1306\",\"WebUI\",\"rtl_433\"]","mf":"OMG_community","cu":"http://192.168.0.25/","sw":"1.8 cbtest_fsk_433"}}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":10,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":55268,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":0,"msgblck":0,"msgrcv":14,"maxq":0,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-37,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":10,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":54872,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":0,"msgblck":0,"msgrcv":15,"maxq":0,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-38,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/SSD1306toMQTT msg: {"onstate":true,"brightness":50,"display-flip":true,"idlelogo":true,"log-oled":false,"json-oled":true}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.9,"rssithreshold":-82,"rssi":-109,"avgrssi":0,"count":0,"rtl433_stack":59480,"ookthreshold":12}
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/WebUItoMQTT msg: {"displayMetric":true,"webUISecure":true,"displayQueue":0}
rtl_433_ESP(7): Average RSSI Signal -113 dbm, adjusted RSSI Threshold -104, samples 50000
rtl_433_ESP(7): Average RSSI Signal -112 dbm, adjusted RSSI Threshold -103, samples 50000
T: Enqueue JSON
T: Queue length: 1
N: SYS json: {"uptime":130,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":63292,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":19,"msgblck":0,"msgrcv":19,"maxq":19,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-39,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":"'LilyGo_SSD1306', 'WebUI', 'rtl_433'","origin":"/SYStoMQTT"}
T: Enqueue JSON
T: Queue length: 2
T: Enqueue JSON
T: Queue length: 3
T: Enqueue JSON
T: Queue length: 4
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":130,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":63292,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":19,"msgblck":0,"msgrcv":19,"maxq":19,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-39,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.9,"rssithreshold":-103,"rssi":-114,"avgrssi":-112,"count":0,"rtl433_stack":59480,"ookthreshold":12}
T: Dequeue JSON
rtl_433_ESP(7): Average RSSI Signal -110 dbm, adjusted RSSI Threshold -101, samples 50000
T: Enqueue JSON
T: Queue length: 1
N: SYS json: {"uptime":250,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":63284,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":23,"msgblck":0,"msgrcv":23,"maxq":19,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-39,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":"'LilyGo_SSD1306', 'WebUI', 'rtl_433'","origin":"/SYStoMQTT"}
T: Enqueue JSON
T: Queue length: 2
T: Enqueue JSON
T: Queue length: 3
T: Enqueue JSON
T: Queue length: 4
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":250,"version":"1.8 cbtest_fsk_433","mqtt":true,"serial":false,"disc":true,"ohdisc":true,"env":"lilygo-rtl_433-fsk-cbtest-433","freemem":63284,"mqttp":"1883","mqtts":false,"mqttv":false,"msgprc":23,"msgblck":0,"msgrcv":23,"maxq":19,"cnt_index":0,"minmem":13888,"tempc":50,"freestck":3532,"powermode":-1,"eth":false,"rssi":-39,"SSID":"Hans Christian Andersen","BSSID":"5C:49:79:64:01:7D","ip":"192.168.0.25","mac":"D4:D4:DA:82:ED:2C","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
T: Dequeue JSON
N: [ OMG->MQTT ] topic: OMG/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.9,"rssithreshold":-103,"rssi":-110,"avgrssi":-112,"count":0,"rtl433_stack":59480,"ookthreshold":12}
T: Dequeue JSON
pulse_slicer_pcm: Ambient Weather WH31E Thermo-Hygrometer Sensor, EcoWitt WH40 rain gauge codes [{267}f3bfffffa7f5bff7f91fb7ff47fefff7ff4ffd7fe7fa3fbcfff7feff9df80fffff0]
pulse_slicer_pcm: TBH weather sensor codes [{71}bfbfcfdff7eddfee7c]
pulse_slicer_pcm: Badger ORION water meter, 100kbps (-f 916.45M -s 1200k) codes [{1504}fffff001ffff01fffffffffffffffffffffffffffffffe0fc007fffffffff83f03ffc1fffffffffffffe03ffffffffffe003f00007fffffffe07ff03ffffffffffffffe0fc0001fffffffffffffe0fffffffffffffffff03fffffffffffffff81f800ffffffffffffff07e07fffffffffffffe003ffffffffffe07f0000ffffffffff03fffff800fffffffffffffffff03fffffffffffffe0ffffffffffffe003fffc1ffffffff80000000007fffffffffffffffffffffffffff0000]
bresser_5in1_decode: bit_per_row 114 out of range
pulse_slicer_pcm: Bresser Weather Center 5-in-1 codes [{114}d7feff79ff7fff9ffbefbfff78ff8]
bresser_6in1_decode: bit_per_row 114 out of range
pulse_slicer_pcm: Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A codes [{114}d7feff79ff7fff9ffbefbfff78ff8]
bresser_7in1_decode: to few bits (114)
pulse_slicer_pcm: Bresser Weather Center 7-in-1 codes [{114}d7feff79ff7fff9ffbefbfff78ff8]
pulse_slicer_pcm: Cavius smoke, heat and water detector codes [{71}bfbfcfdff7eddfee7c]
pulse_slicer_pcm: CurrentCost Current Sensor codes [{52}0004400080061]
pulse_slicer_pcm: Danfoss CFR Thermostat codes [{161}dbfff7afefa75fa7efefd7ebf7d3dbfbf7df0ffe0]
directv_decode: incorrect number of bits in bitbuffer: 21 (expected between
pulse_slicer_pcm: DirecTV RC66RX Remote Control codes [{21}ffffd8]
ecodhome_decode: to few bits (52)
pulse_slicer_pcm: EcoDHOME Smart Socket and MCEE Solar monitor codes [{52}fffbbfff7ff9e]
pulse_slicer_pwm: Efergy e2 classic codes [{2}0, {1}8, {2}8, {1}8, {1}0, {1}8, {1}8, {1}8, {1}8, {1}0, {1}0, {0}]
pulse_slicer_pwm: Efergy Optical codes [{2}0, {1}8, {2}8, {1}8, {1}0, {1}8, {1}8, {1}8, {1}8, {1}0, {1}0, {0}]
pulse_slicer_pcm: Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor codes [{174}dbfff5eafdf4f5fd3f7fbfafd7efa7bbfdfbf6f0fff0]
pulse_slicer_pcm: emonTx OpenEnergyMonitor codes [{741}ffc0ff1fffffffffffffffce07ffff8e3f3ffffff8fffffc1c03fffe3f1fffffff8e00fffffff1ffffffff8fffffffe381ffffffe38fffffff07ffffe3807ffff1ffc1ffffffff1ffffffe3fffffe0ff3fffe00003fffffffffffff800]
pulse_slicer_pcm: ESIC EMT7110 power meter codes [{153}dbffef5fbd3afd3efefd7d7ef4f6feffdf0ffe0]
pulse_slicer_pcm: Fine Offset Electronics, WH25, WH32B, WH24, WH65B, HP1000, Misol WS2320 Temperature/Humidity/Pressure Sensor codes [{264}e77ffffe9fd6ffdfe47edffd1ffbffdffd3ff5ff9fe8fef3ffdffbfe77e03ffff8]
fineoffset_WH51_callback: short package. Header index: 288 codes [{264}e77ffffe9fd6ffdfe47edffd1ffbffdffd3ff5ff9fe8fef3ffdffbfe77e03ffff8]
inkbird_ith20r_callback: bit_per_row 161 out of range
pulse_slicer_pcm: Inkbird ITH-20R temperature humidity sensor codes [{161}dbfff7afefa75fa7efefd7ebf7d3dbfbf7df0ffe0]
inkbird_ith20r_callback: bit_per_row 81 out of range
pulse_slicer_pcm: Inkbird ITH-20R temperature humidity sensor codes [{81}faff83ff4babd7bfcfde0]
inkbird_ith20r_callback: bit_per_row 105 out of range
pulse_slicer_pcm: Inkbird ITH-20R temperature humidity sensor codes [{105}ffff55449ffffffffff56d532d0]
What else can I do to find the reason for this issue?
Regrds, Christoph
