A quick query, sorry if someone has brought it up before, I couldn’t see any information about it.
The m5stick and m5stack projects provide a number of add on sensors attached via grove ports.
one of these sensors is the fairly low cost RF433R 433MHz module, based on the SYN513R chip.
The product is here: RF UNIT 433MHz Receiver (SYN513R) | m5stack-store
and the specification is here: https://docs.m5stack.com/en/unit/rf433_r
Is there scope to have this device available as an additional sensor on the Stick/Stack firmwares? or is the module too limited?
If it were possible, it would make deploying a solution that is compatible with the protocol a little easier and less technical for end users.
