I have designed and tested a PCB for OMG. It comes with the following features:
- IR (RX/TX)
- RF (RX/TX)
- PIR
- DHT
- Bluetooth
It is based around the ESP8266. Right now there is only a SMD version of the Board available, although all components are easy to solder. But if there is demand I maybe design a THT version as well.
You can find all further here:
Next steps will be to design a Case around it, and then maybe a version which doesn’t use all the modules separately, instead has all the components directly on the PCB, but we will see.
