How to solder that on a Superheterodyne receiver ?
On my previous system I used a female SMA connector like below:
Cut it and connect the center wire to ANT and the shielding to the ground.
You can also directly cut the antenna wire but in my case I prefered to keep the possibility to change the antenna.
Thanks. (Minimal 20 chars)
