/-------------------VERSION----------------------/
#define OMG_VERSION “0.9”
/-------------CONFIGURE WIFIMANAGER-------------(only ESP8266 & SONOFF RFBridge)/
- The following parameters are set during the WifiManager setup process:
- To completely disable WifiManager, define ESPWifiManualSetup.
- If you do so, please don’t forget to set these variables before compiling
- Otherwise you can provide these credentials on the web interface after connecting
- to the access point with your password (SSID: WifiManager_ssid, password: WifiManager_password)
/-------------DEFINE YOUR NETWORK PARAMETERS BELOW----------------/
#if defined(ESP8266) // for nodemcu, weemos and esp8266
//#define ESPWifiManualSetup true //uncomment you don’t want to use wifimanager for your credential settings on ESP
#endif
#if defined(ESP32) || defined(ESPWifiManualSetup) // for nodemcu, weemos and esp8266
#define wifi_ssid “wifi ssid”
#define wifi_password “wifi password”
#else // for arduino + W5100
const byte mac[] = { 0x00, 0x24, 0x1B, 0x14, 0xA7, 0x3F }; //W5100 ethernet shield mac adress
#endif
#define WifiManager_password “your_password” //this is going to be the WPA2-PSK password for the initial setup access point
#define WifiManager_ssid “OpenMQTTGateway” //this is the network name of the initial setup access point
#define WifiManager_ConfigPortalTimeOut 120
/-------------DEFINE YOUR MQTT PARAMETERS BELOW----------------/
//MQTT Parameters definition
//#define mqtt_server_name “www.mqtt_broker.com” // instead of defining the server by its IP you can define it by its name, uncomment this line and set the correct MQTT server host name
char mqtt_user[20] = “xxxx”; // not compulsory only if your broker needs authentication
char mqtt_pass[30] = “xxxx”; // not compulsory only if your broker needs authentication
char mqtt_server[40] = “192.168.0.34”;
char mqtt_port[6] = “1883”;
#define Gateway_Name “OpenMQTTGateway”
//uncomment the line below to integrate msg value into the subject when receiving
//#define valueAsASubject true
/-------------DEFINE THE MODULES YOU WANT BELOW----------------/
//Addons and module management, comment the Z line
#define ZgatewayRF “RF” //ESP8266, Arduino, ESP32
//#define ZgatewayRF315 “RF315” //ESP8266, Arduino, ESP32
//#define ZgatewayPilight “Pilight” //ESP8266, Arduino, ESP32
//#define ZgatewayBT “BT” //ESP8266, Arduino, ESP32
//#define ZgatewaySRFB “SRFB” // Sonoff RF Bridge
//#define Zgateway2G “2G” //ESP8266, Arduino, ESP32
//#define ZgatewayRFM69 “RFM69” //ESP8266, Arduino, ESP32
//#define ZactuatorONOFF “ONOFF” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorINA226 “INA226” //ESP8266, Arduino, ESP32
//#define ZsensorHCSR501 “HCSR501” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorADC “ADC” //ESP8266, Arduino, ESP32
//#define ZsensorBH1750 “BH1750” //ESP8266, Arduino, ESP32
//#define ZsensorTSL2561 “TSL2561” //ESP8266, Arduino, ESP32
//#define ZsensorBME280 “BME280” //ESP8266, Arduino, ESP32
//#define ZsensorDHT “DHT” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorGPIOKeyCode “GPIOKeyCode” //ESP8266, Arduino, ESP32
//#define ZsensorGPIOInput “GPIOInput” //ESP8266, Arduino, ESP32
//#define ZmqttDiscovery “HADiscovery”//ESP8266, Arduino, ESP32, Sonoff RF Bridge
/-------------DEFINE YOUR ADVANCED NETWORK PARAMETERS BELOW----------------/
//#define MDNS_SD //uncomment if you want to use mdns for discovering automatically your ip server, please note that MDNS with ESP32 can cause the BLE to not work
#define maxMQTTretry 4 //maximum MQTT connection attempts before going to wifi setup
//set minimum quality of signal so it ignores AP’s under that quality
#define MinimumWifiSignalQuality 8
// these values are only used if no dhcp configuration is available
const byte ip[] = { 192, 168, 0, 50 }; //ip adress
const byte gateway[] = { 192, 168, 0, 1 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte Dns[] = { 0, 0, 0, 0 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte subnet[] = { 255, 255, 255, 0 }; //ip adress
/-------------DEFINE YOUR MQTT ADVANCED PARAMETERS BELOW----------------/
#define Base_Topic “home/”
#define version_Topic Base_Topic Gateway_Name “/version”
#define will_Topic Base_Topic Gateway_Name “/LWT”
#define will_QoS 0
#define will_Retain true
#define will_Message “offline”
#define Gateway_AnnouncementMsg “online”
#define jsonPublishing true //comment if you don’t want to use Json publishing (one topic for all the parameters)
//example home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4 {“rssi”:-63,“servicedata”:“fe0000000000000000000000000000000000000000”}
#define jsonReceiving true //comment if you don’t want to use Json reception analysis
//#define simplePublishing true //comment if you don’t want to use simple publishing (one topic for one parameter)
//example
// home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4/rssi -63.0
// home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4/servicedata fe0000000000000000000000000000000000000000
#define simpleReceiving true //comment if you don’t want to use old way reception analysis
/-------------DEFINE YOUR OTA PARAMETERS BELOW----------------/
#define ota_hostname Gateway_Name
#define ota_password “OTAPASSWORD”
#define ota_port 8266
/-------------DEFINE PINs FOR STATUS LEDs----------------/
#define led_receive 40
#define led_send 42
#define led_error 44
// VCC ------------D|-----------////\ ----------------- Arduino PIN
// LED Resistor 270-510R
/----------------------------OTHER PARAMETERS-----------------------------/
/-------------------CHANGING THEM IS NOT COMPULSORY-----------------------/
/----------------------------USER PARAMETERS-----------------------------/
#ifdef ZgatewaySRFB
#define SERIAL_BAUD 19200
#else
#define SERIAL_BAUD 115200
#endif
/--------------MQTT general topics-----------------/
// global MQTT subject listened by the gateway to execute commands (send RF, IR or others)
#define subjectMQTTtoX Base_Topic Gateway_Name “/commands/#”
#define subjectMultiGTWKey “toMQTT”
#define subjectGTWSendKey “MQTTto”
//variables to avoid duplicates
#define time_avoid_duplicate 3000 // if you want to avoid duplicate mqtt message received set this to > 0, the value is the time in milliseconds during which we don’t publish duplicates
//uncomment to use multicore function of ESP32 for BLE
#ifdef ESP32
#define multiCore //comment to don’t use multicore function of ESP32 for BLE
#endif
#define JSON_MSG_BUFFER 512 // Json message max buffer size, don’t put 1024 or higher it is causing unexpected behaviour on ESP8266
#define TimeBetweenReadingSYS 120000 // time between system readings (like memory)
#define subjectSYStoMQTT Base_Topic Gateway_Name “/SYStoMQTT”
/-------------------ACTIVATE TRACES----------------------/
#define TRACE 1 // commented = trace off, uncommented = trace on
