BLE and ESP32 dev environment
Hi Florian,
Yes, latest version. MQTT connection is made however there’s no info in the serial connection (and Arduino boards don’t have the option for compiling with debug flag).
So, compiled without the vTaskDelay and on core 1 instead of 0. It worked for about 12 hours then it got disconnected.
[D][BLEUtils.cpp:1091] dumpGapEvent(): Received a GAP event: ESP_GAE (4065634) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (4065634) task_wdt:  - IDLE0 (CPU 0)
E (4065634) task_wdt: Tasks currently running:
E (4065634) task_wdt: CPU 0: wifi
E (4065634) task_wdt: CPU 1: loopTask
E (4070634) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (4070634) task_wdt:  - IDLE0 (CPU 0)
E (4070634) task_wdt: Tasks currently running:
E (4070634) task_wdt: CPU 0: wifi
E (4070634) task_wdt: CPU 1: loopTask
and so on…
Previously it dropped the MQTT connection however it did recover:
BT Task running on core 1
[D][WiFiClient.cpp:452] connected(): Disconnected: RES: 0, ERR: 128
MQTT connection...
Connected to broker
[D][BLEScan.cpp:196] start(): >> start(duration=10)
[D][BLEScan.cpp:221] start(): << start()
[D][BLEUtils.cpp:1091] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_SCAN_PARAM_SET_COMPLETE_EVT
[D][BLEUtils.cpp:1229] dumpGapEvent(): [status: 0]
[D][BLEUtils.cpp:1091] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_SCAN_START_COMPLETE_EVT
[D][BLEUtils.cpp:1305] dumpGapEvent(): [status: 0]
[D][BLEUtils.cpp:1091] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_SCAN_RESULT_EVT
Thanks for the info, I take a look
I’ve tested bit without serial output and it seems working so far but rebooting .unfortunately I don’t know the cause. I might attach it again on the laptop to debig but as long as it reboots and works it’s fine for me I used vtask delay and using core one option .
the other option that I’m testing right now is (if you don’t use RF) to deactivate multicore by commenting the following line:
As my environment doesn’t enable me to reproduce watchdog issue, if you could test with:
-multicore disabled
-without vtaskdelay
It could help us
I’ll try it once I’m at home again this afternoon. ESP just went offline. Will revert :slight_smile:
I compiled mine with BT and mqtt as the only services and deactivated multicore
so far my uptime is "uptime":100751
when i left multicore enabled, core 1 would be crashing the chip periodically
Still :running_man:? Would like having a feedback
it was running for over 48 hrs without reboots
Hello @blakadder adder,
Since your last post is it still running?
@thundergreen
Could you test to add in the begining of OpenMQTTGateway.ino at the begining:
#include "soc/timer_group_struct.h"
#include "soc/timer_group_reg.h"
and in the loop
TIMERG0.wdt_wprotect=TIMG_WDT_WKEY_VALUE;
TIMERG0.wdt_feed=1;
TIMERG0.wdt_wprotect=0;
This will enable to test the tip given by @akshar001
You have to restore a fresh ZgatewayBT.ino to cancel your previous changes
Unfortunately my Arduino broke… Can’t start it …have exception error…no idea what happened need to compile online I guess…I’ll try that.please always post the exact file location as an example as I’m noob with programming…I really wanna help but need assistance…sorry for this dumbness
Edit: sorry u did add th file and indicator to change :wink:
Current uptime 87 hrs
So i want use ESP32 and BT. What version i must use? Is all this changes implemented or i must correct it?
you can take v0.8 and deactivate multicore.
If you want to participate I’m also interested by your feedback with multicore activated.
14+ days of constant uptime with the 0.8 version, running only the BT component, multicore deactivated
Thanks for the info, I added a comment into the wiki:
For info mine is running with multicore activated since more than 2 weeks also.
