Buy a ready2use OMG device
I asked @1technophile if it’s ok to post an ad here, and he is fine with it.
I already have this thread on the home assistant forum, which is about zigbee2mqtt.
I wanted to make something similar with OMG. So currently I have 3 devices.
  • ESP32 with RF, BLE and an LED.
  • NodeMCU ESP8266 version with RF and an LED.
  • ESP32 with BLE
As the pictures show I also have a prototype with IR.
If you are interested please contact me via private message
OR
via email: h4nc.zigbee(a)gmail.com
Looks very cool.
Could you tell us about the RF receiver/transmitter module and antennas?
I use STX882/SRX882 mosules as recommend here.
The antenna pin is connected to a female sma connector.
It commes with two 3dbi male sma antennas. But you can change it to any 433Mhz antenna you like. With a SMA/BNC adapter you could also use those antennas (of course in this case the hole in the top case has to be a little bigger).
Those look like a customised pcbs to put all the components together? Could you share how you got them?
Would love to see how you RF + IR prototype looks like
I designed them myself and ordered them from a manufacturer.
You can see the in the picture with the blue background. It’s the first one. Did not make a case for that one yet.
Not yet finished, but this is how the IR version of the OMG devices will look like.
The esp32 v
ersion will support IR/RF/BLE/LED
Same for the Esp8266 version but without BLE.
I finished the IR Versions of the OpenMqttgateway.
I made two versions:
OMG ESP32 IR/RF/BLE/LED
OMG ESP8266 IR/RF/LED
This is how they look:
Could not edit the post above to change the pictures. So here are two additional ones:
I’m now also able to flash the Sonoff RF Bridge with OpenMqttGateway.
You may ask yourself why I want to offer flashed Sonoff RF Bridges when I already have the DIY OMG IR/RF/BLE/Led device.
Well first of all if someone only wants RF (in an industrial case) the Sonoff RF may be the better choice. And because I only need to flash it and save a lot of time soldering and making the device it will be cheaper.
So I think it’s nice to have this option too.
Would be nice if u share your PCB design with us :slight_smile: I would like to use it.
Thanks for your interest. I’ll consider to do so and if I decide to provide the files I will post the link in this thread.
