Can not connect to test.mosquitto.org. Are getting faillure rc=5 please se below:
******** WELCOME TO OpenMQTTGateway **************
N: SSD1306 config initialised
[ 139][E][Preferences.cpp:483] getString(): nvs_get_str len fail: SSD1306Config NOT_FOUND
N: No SSD1306 config to load
N: Setup SSD1306 Display end
N: OpenMQTTGateway Version: v1.5.1
“mqtt_server”: “test.mosquitto.org”,
“mqtt_port”: “1883”,
“mqtt_user”: “your_username”,
“mqtt_pass”: “your_password”,
“mqtt_topic”: “home/”,
“gateway_name”: “OpenMQTTGateway_lilygo_rtl_433_ESP”,
“mqtt_broker_secure”: false,
“mqtt_broker_cert”: “”,
“mqtt_ss_index”: 0,
“ota_server_cert”: “”,
“ota_pass”: “OTAPASSWORD”
*wm:[2] Added Parameter: pass
*wm:[2] Added Parameter: cert
*wm:[2] Added Parameter: name
*wm:[2] Added Parameter: ota
N: ZgatewayRTL_433 setup done
N: OpenMQTTGateway modules: [“LilyGo_SSD1306”,“rtl_433”]
W: MQTT connection…
W: failure_number_mqtt: 1
W: failed, rc=5
W: MQTT connection…
W: failure_number_mqtt: 2
W: failed, rc=5
W: MQTT connection…
W: failure_number_mqtt: 3
W: f
Best regards
Lars
