Hi Florian,
i added all my sensors through the Xiaomi Home application when i installed them in Home Assistant. All have been recognized thourgh BLE Monitor add on.
i used them into Home Assistant through BLE monitor and i have correct status from them.
When all are closed i have the following :
192.168.20.26
home
OpenMQTTGateway_ESP32_BLE
BTtoMQTT
582D3460184A = {“id”:“58:2D:34:60:18:4A”,“name”:“Qingping Door/Window Sensor”,“rssi”:-83,“servicedata”:“3058d603104a1860342d5808”}
582D34600867 = {“id”:“58:2D:34:60:08:67”,“name”:“Qingping Door/Window Sensor”,“rssi”:-54,“servicedata”:“3058d60352670860342d5808”}
582D34601D58 = {“id”:“58:2D:34:60:1D:58”,“name”:“Qingping Door/Window Sensor”,“rssi”:-70,“servicedata”:“3058d603cc581d60342d5808”}
582D3460087C = {“id”:“58:2D:34:60:08:7C”,“name”:“Qingping Door/Window Sensor”,“rssi”:-70,“servicedata”:“3058d6033c7c0860342d5808”}
When all windows are opened i have the following :
192.168.20.26
home
BTtoMQTT
582D34600867 = {“id”:“58:2D:34:60:08:67”,“name”:“Qingping Door/Window Sensor”,“rssi”:-65,“servicedata”:“3058d60309670860342d5808”}
582D3460184A = {“id”:“58:2D:34:60:18:4A”,“name”:“Qingping Door/Window Sensor”,“rssi”:-77,“servicedata”:“3058d6039d4a1860342d5808”}
582D34601D58 = {“id”:“58:2D:34:60:1D:58”,“name”:“Qingping Door/Window Sensor”,“rssi”:-73,“servicedata”:“3058d6037f581d60342d5808”}
582D3460087C = {“id”:“58:2D:34:60:08:7C”,“name”:“Qingping Door/Window Sensor”,“rssi”:-70,“servicedata”:“3058d603f17c0860342d5808”}
i disable bluetooth on my phone.
i disable all sensors in Home Assistant.
After a restart, i got this in MQTT Explorer
192.168.20.26
▼home
▼OpenMQTTGateway_ESP32_BLE
▼BTtoMQTT
582D34601D58 = {“id”:“58:2D:34:60:1D:58”,“name”:“Qingping Door/Window Sensor”,“rssi”:-69,“servicedata”:“3058d6038d581d60342d5808”}
582D3460184A = {“id”:“58:2D:34:60:18:4A”,“name”:“Qingping Door/Window Sensor”,“rssi”:-80,“servicedata”:“3058d603a74a1860342d5808”}
582D34600867 = {“id”:“58:2D:34:60:08:67”,“name”:“Qingping Door/Window Sensor”,“rssi”:-56,“servicedata”:“3058d60315670860342d5808”}
582D3460087C = {“id”:“58:2D:34:60:08:7C”,“name”:“Qingping Door/Window Sensor”,“rssi”:-65,“servicedata”:“3058d603f97c0860342d5808”}
same behavior.
in your ZgatewayBT.ino file, in process_cgh1 function, i don’t undersand “0804”, “8804” etc… values. these values are not present in my Servicedata values
Thanks for you support.
Regards
Laurent.
