Compiling OpenMQTTGateway with RTL_433 support
Hi
platformio , ESP32 dev board v4 , CC1101 transmitter
i try to compile OpenMQTTGateway 0.9.6 with RTL_433 support
in platformio.ini i use : default_envs = esp32dev-rf
in User_config.h i dont find any related to RTL_433 , so i add a line : #define ZgatewayRTL_433 “RTL_433” //ESP32
i also uncomment : #define ZradioCC1101 “CC1101” //ESP8266, ESP32
but compilation terminated with these errors :
C:/…/OpenMQTTGateway-0.9.6/main/ZgatewayRF.ino:33:39: fatal error: ELECHOUSE_CC1101_SRC_DRV.h: No such
file or directory
  • Looking for ELECHOUSE_CC1101_SRC_DRV.h dependency? Check our library registry!
  • CLI > platformio lib search “header:ELECHOUSE_CC1101_SRC_DRV.h”
  • Web > PlatformIO Registry
include <ELECHOUSE_CC1101_SRC_DRV.h>
compilation terminated.
*** [.pio\build\esp32dev-rf\src\main.ino.cpp.o] Error 1
C:/…/OpenMQTTGateway-0.9.6/main/ZgatewayRTL_433.ino:33:26: fatal error: rtl_433_ESP.h: No such file or
directory
  • Looking for rtl_433_ESP.h dependency? Check our library registry!
  • CLI > platformio lib search “header:rtl_433_ESP.h”
include <rtl_433_ESP.h>
what i am doing wrong ?
for any hints thanks in advance
Try using the predefined ESP32 rtl_433 environment
[env:esp32dev-rtl_433]
to start with. It already has the rtl_433 lib dep and ‘-DZradioCC1101=“CC1101”’ included.
Hope this helps
hi
thanks for the reply
in platformio.ini
i added the line :
default_envs = esp32dev-rtl_433
in User_config.h
i uncomment :
now compiling and flashing works , thanks for that
i get only SYStoMQT mqtt messages :
N: Subject: /SYStoMQTT
N: Received json : {“uptime”:1202,“version”:“version_tag”,“freemem”:141632,“freestack”:4200,“rssi”:-34,“SSID”:“meinwan”,“ip”:“192.168.2.182”,“mac”:“84:CC:A8:5E:7C:B0”,“mhz”:433,“RTLminRssi”:-82,“RTLRssi”:-66,“RTLCnt”:0,“modules”:[“RTL_433”]}
but not reciving any data
how i can check the CC1101 is working ?
i did the wiring in this way : SmartRC-CC1101-Driver-Lib/Esp32_CC1101.png at master · LSatan/SmartRC-CC1101-Driver-Lib · GitHub
but the pinout divers from here : RF gateway (433mhz/315mhz) | OpenMQTTGateway v0.9.6
pins 27/26 and 12
which is the right one ?
thanks for any help
Hi
i changed the antenna and i get messages to my mqttbroker :
{“model”:“unknown”,“protocol”:“signal parsing failed”,“duration”:3350994,“signalRssi”:-49,“pulses”:67,“train”:0,“messageCount”:8,"_enabledReceiver":1,“receiveMode”:0,“currentRssi”:-138,“minimumRssi”:-82}
and messages to the serial konsole in platformio :
rtl_433_ESP(6): Unparsed Signal length: 214930349, Signal RSSI: -70, train: 1, messageCount: 3, pulses: 328
rtl_433_ESP(6): RAW (214930349): with a bunch of nummbers
so wiring seems ok
tomorow i take a deeper look in the data , maybe adjust the frequency
Yes, and that now uses the environment defined further down in platformio.ini - line 538(ish) onwards
board = esp32dev
  ${libraries.rtl_433_ESP}
  '-DZradioCC1101="CC1101"'
  '-DZgatewayRTL_433="rtl_433"'
  '-DGateway_Name="OpenMQTTGateway_rtl_433_ESP"'
  '-DRF_RECEIVER_GPIO=4'
;  '-DRTL_DEBUG=4'        ; enable rtl_433 verbose device decode
Therefor you don’t actually have to make any changes in User_config.h at all.
The default receiver pin for rtl_433 is 4, as defined in the environemt above - ‘-DRF_RECEIVER_GPIO=4’ - so if you hooked up your ESP32 as in
you should be fine.
What rtl_433 devices do you have for which you are expecting signal messages?
Crosstalked just now :wink:
To change the frequency you can just add a build flag for it to the environment, e.g.
'-DCC1101_FREQUENCY=868.32'
All the best
Hi
i have some digoo temperature sensors and 433mhz plugs (dont know the factury)
the temperature sensors are recived by an d1mini-esp8266 + RBX6 with rflink-ESP
the plugs are recived by d1mini-esp8266 + RBX6 with opengateway RF aswell Pilight
and RFtech temperature sensors wich are not recognized from rflink-Esp nor RF and Pilight so i hope RTL_433 do this for all
yes crossing :wink:
and a 868 mhz conrad weatherstation
i take a look tomorow
thanks for the help
Your RFtech temperature sensors might be recognised, depending on their model, as there is an RFtech decoder included in RTL_433_ESP.
With your 868Mhz Conrad weather station you might have a similar issue as I have with my weather station. They mostly seem to use FSK modulation, which is not supported in RTL_433_ESP yet, but @NorthernMan54 is testing and working on it, so it’ll hopefully be included in a future release.
