Just got OMG set up on my ESP32 and I see that it is resetting every 30 seconds or so:
WiFi ok with manual config credentials
OpenMQTTGateway mac:
CC:50:E3:80:A9:14
OpenMQTTGateway ip:
192.168.0.19
1883
192.168.0.25
IR_EMITTER_PIN
14
IR_RECEIVER_PIN
27
ZgatewayIR setup done
RF_EMITTER_PIN
12
RF_RECEIVER_PIN
13
ZgatewayRF setup done
ZgatewayBT multicore ESP32 setup done
BT Task running on core 0
MQTT_MAX_PACKET_SIZE
1024
Setup OpenMQTTGateway end
MQTT connection...
Connected to broker
Guru Meditation Error: Core 1 panic'ed (Cache disabled but cached memory region accessed)
Core 1 register dump:
PC : 0x400dcce8 PS : 0x00060034 A0 : 0x40081864 A1 : 0x3ffc0bf0
A2 : 0x00000001 A3 : 0x00000002 A4 : 0x000000ff A5 : 0x400905d0
A6 : 0x00000000 A7 : 0x1300045c A8 : 0x80081388 A9 : 0x3ff5f024
A10 : 0x3ffc1170 A11 : 0x20000000 A12 : 0x00000400 A13 : 0x00000000
A14 : 0x3ffc8584 A15 : 0xffffffff SAR : 0x00000016 EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40082407 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x400dcce8
Backtrace: 0x400dcce8:0x3ffc0bf0 0x40081861:0x3ffc0c10 0x40082404:0x00000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13256
entry 0x40078a90
Connecting to
Any idea why this might be? Also, does it relay all BT devices it detects? I’m not seeing any BT broadcasts. I haven’t connecting RF yet so I don’t see that either but I do see the initial version and LWT messages on my MQTT.
The board I have claims to be an NodeMCU32-S … I tried compiling with that board type and I get this:
Sketch uses 1630978 bytes (124%) of program storage space. Maximum is 1310720 bytes.
Global variables use 75184 bytes (25%) of dynamic memory, leaving 219728 bytes for local variables. Maximum is 294912 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board NodeMCU-32S
WARNING: library WiFi claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
WARNING: library ArduinoOTA claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
WARNING: library Update claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
WARNING: library ESP32_BLE_Arduino claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
WARNING: library rc-switch claims to run on (avr, esp8266, esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
WARNING: library ESPmDNS claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (arduino-esp32) architecture(s).
Sketch uses 1636286 bytes (83%) of program storage space. Maximum is 1966080 bytes.
Global variables use 75248 bytes (25%) of dynamic memory, leaving 219664 bytes for local variables. Maximum is 294912 bytes.
esptool.py v2.3.1
Connecting........_____....._____.....__
Chip is ESP32D0WDQ6 (revision (unknown 0xa))
Features: WiFi, BT, Dual Core, VRef calibration in efuse
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 655.4 kbit/s)...
Hash of data verified.
Compressed 14320 bytes to 9346...
Writing at 0x00001000... (100 %)
Wrote 14320 bytes (9346 compressed) at 0x00001000 in 0.9 seconds (effective 123.4 kbit/s)...
Compressed 1637440 bytes to 913975...
Writing at 0x00010000... (1 %)
Writing at 0x00014000... (3 %)
Writing at 0x00018000... (5 %)
Writing at 0x0001c000... (7 %)
Writing at 0x00020000... (8 %)
Writing at 0x00024000... (10 %)
Writing at 0x00028000... (12 %)
Writing at 0x0002c000... (14 %)
Writing at 0x00030000... (16 %)
Writing at 0x00034000... (17 %)
Writing at 0x00038000... (19 %)
Writing at 0x0003c000... (21 %)
Writing at 0x00040000... (23 %)
Writing at 0x00044000... (25 %)
Writing at 0x00048000... (26 %)
Writing at 0x0004c000... (28 %)
Writing at 0x00050000... (30 %)
Writing at 0x00054000... (32 %)
Writing at 0x00058000... (33 %)
Writing at 0x0005c000... (35 %)
Writing at 0x00060000... (37 %)
Writing at 0x00064000... (39 %)
Writing at 0x00068000... (41 %)
Writing at 0x0006c000... (42 %)
Writing at 0x00070000... (44 %)
Writing at 0x00074000... (46 %)
Writing at 0x00078000... (48 %)
Writing at 0x0007c000... (50 %)
Writing at 0x00080000... (51 %)
Writing at 0x00084000... (53 %)
Writing at 0x00088000... (55 %)
Writing at 0x0008c000... (57 %)
Writing at 0x00090000... (58 %)
Writing at 0x00094000... (60 %)
Writing at 0x00098000... (62 %)
Writing at 0x0009c000... (64 %)
Writing at 0x000a0000... (66 %)
Writing at 0x000a4000... (67 %)
Writing at 0x000a8000... (69 %)
Writing at 0x000ac000... (71 %)
Writing at 0x000b0000... (73 %)
Writing at 0x000b4000... (75 %)
Writing at 0x000b8000... (76 %)
Writing at 0x000bc000... (78 %)
Writing at 0x000c0000... (80 %)
Writing at 0x000c4000... (82 %)
Writing at 0x000c8000... (83 %)
Writing at 0x000cc000... (85 %)
Writing at 0x000d0000... (87 %)
Writing at 0x000d4000... (89 %)
Writing at 0x000d8000... (91 %)
Writing at 0x000dc000... (92 %)
Writing at 0x000e0000... (94 %)
Writing at 0x000e4000... (96 %)
Writing at 0x000e8000... (98 %)
Writing at 0x000ec000... (100 %)
Wrote 1637440 bytes (913975 compressed) at 0x00010000 in 86.0 seconds (effective 152.3 kbit/s)...
Compressed 3072 bytes to 144...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.1 seconds (effective 234.1 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Invalid library found in C:\Users\User\Documents\Arduino-esp32\hardware\espressif\arduino-esp32\libraries\AzureIoT: no headers files (.h) found in C:\Users\User\Documents\Arduino-esp32\hardware\espressif\arduino-esp32\libraries\AzureIoT
Invalid library found in C:\Users\User\Documents\Arduino-esp32\hardware\espressif\arduino-esp32\libraries\BLE: no headers files (.h) found in C:\Users\User\Documents\Arduino-esp32\hardware\espressif\arduino-esp32\libraries\BLE
Also, how do you totally clear the settings in the chip? I tried using the WIFI manager but when it came back up after flashing it was connecting to my SSID like it was prior to flashing.
Ok, you should not have memory space issue with these settings.
Regarding wifimanager it is not currently supported with esp32. You have to set your credentials into user_config.h.
I just did an erase using ESP32 download tool and running just BT and it seems to be stable and broadcasting BT information. This is great. I need to get RF working and things will be good. I’m not sure if something got corrupted and the erase has helped fix it?
Ok… I’m trying again with it hooked up. To make matters worse, the chip I have doesn’t have the pins labeled on the silk screen so I’m not certain where the GPIO pin is that I need to use…
