Could you try to flash it with the ATC firmware please to see if you get data?
My v0.9.9 retrieve data from an ATC one currently, so if it works for you also we may have something wrong with the PVVX decoder:
{"id":"","mac_type":0,"name":"ATC_","rssi":-80,"brand":"Xiaomi","model":"LYWSD03MMC","model_id":"LYWSD03MMC_ATC","tempc":17.3,"tempf":63.14,"hum":51,"batt":16,"volt":2.377}
kapryk
February 2, 2022, 11:23am
22
I have the same issues. Pvvx firmware. Release 0.9.8 is ok. Release 0.9.9 does not read sensors
Found the bug, here is the PR for the decoder:
theengs:development ← theengs:fix-pvvx
opened 11:21PM - 02 Feb 22 UTC
## Description:
Fix PVVX decoder and add a unit testing
https://community.open… mqttgateway.com/t/creating-devices-in-home-assistant/1121/20?u=1technophile
## Checklist:
- [X] The pull request is done against the latest development branch
- [X] Only one feature/fix was added per PR and the code change compiles without warnings
- [X] I accept the [DCO](https://github.com/theengs/decoder/blob/development/docs/participate/development.md#developer-certificate-of-origin).
To use it with OMG you would need to point to the decoder development branch here
by replacing with:
decoder = https://github.com/theengs/decoder.git
Thansk guys!
What’s the easiest way to get this onto the ESP? Is there a way to select 0.9.8 or will there be a 0.9.9.1 soon?
A v0.9.10 is already available
I’m giving up, you guys are too fast for me
