Hi there this is my first here,
So about three years ago i created my RF openMQTTGateway to control my 433 RF fans.
First i started with pilight and raw protocols but it was quite tricky to follow and keep track of the enormous strings read by the receiver. I finally found rc-switch and openMQTTGw, i used back in the time the protocolanalyzer demo from here https://github.com/Martin-Laclaustra/rc-switch/tree/protocollessreceiver/examples/ProtocolAnalyzeDemo (i think) to find the custom protocol. Once added it worked very accurate and the database string of codes for speed where much shorter.
Now i need to change some hardcoded values (the broker ip) due to some changes in the network. I have an old openmqttgateway git folder with the custom protocol added there, and looking now at the current forked RC-switch list of protocols under src/RCSwitch.cpp i can see the list is much larger now, also the protocol string length is kind of different now.
Question is will this custom RF protocol from back in time work in current openmqttgateway.
{ 335, { 35, 2 }, { 1, 2 }, { 2, 1 }, true } // Protocol 8 RF FAN 433
The current rf protocols look like this now
{ 220, 0, { 0, 0 }, 1, { 1, 46 }, { 1, 6 }, { 1, 1 }, false, 2 }, // 29 (NEXA)
Or i have to rerun another protocol analyser?
I can see now that web portal can be enabled to change some of those configs.
