Domoticz integration
I am using openMQTTGateway on an ESP32 (esp32dev-multi_receiver) to report various 433 devices, mainly thermometers, to my Domoticz server wth homeassistant discovery through Mosquitto.
It creates an displays my various 433 devices, but…
For each physical device I get 3 or 4 devices in Domoticz, one for each information from the physical device. ie. for a temp + humidity sensor, in Domoticz I get 4 different devices, one for the temperature, one for the humidity, one for the rssi strength and one for the battery level. Domoticz failed to combine theses as a single combined device.
It seems that it is due to the way openMQTTGateway publishes the information: all 4 measurement have a different id and this prevents Domoticz to recognize these as belonging to the same device.
For one of my device, the config topics are currently:
homeassistant/sensor/Ambientweather-F007TH-2-154-humidity/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"humidity","unit_of_meas":"%","name":"Humidity","uniq_id":"Ambientweather-F007TH-2-154-humidity","val_tpl":"{{ value_json.humidity | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Ambientweather-F007TH-2-154-rssi/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"signal_strength","unit_of_meas":"dB","name":"RSSI","uniq_id":"Ambientweather-F007TH-2-154-rssi","val_tpl":"{{ value_json.rssi | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Ambientweather-F007TH-2-154-temperature_C/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"temperature","unit_of_meas":"°C","name":"Temperature","uniq_id":"Ambientweather-F007TH-2-154-temperature_C","val_tpl":"{{ value_json.temperature_C | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/binary_sensor/Ambientweather-F007TH-2-154-battery_ok/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"battery","name":"Battery","uniq_id":"Ambientweather-F007TH-2-154-battery_ok","val_tpl":"{{ value_json.battery_ok | is_defined }}","pl_on":"0","pl_off":"1","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
From readings and discussions in the Domoticz forums, I think that to be combined by Domoticz, the config topics should be (note the ‘/’ instead of “_”):
homeassistant/sensor/Ambientweather-F007TH-2-154/humidity/config
{"stat_t":"+/+/RTL_43...
homeassistant/sensor/Ambientweather-F007TH-2-154/rssi/config
homeassistant/sensor/Ambientweather-F007TH-2-154/temperature_C/config
homeassistant/binary_sensor/Ambientweather-F007TH-2-154/battery_ok/config
Questions:
  1. has someone already encountered this problem?
  2. to test this, is there a simple way to modifiy these config topics without modifying the source code?
After more investigations, the problem may also come from mixed formats in the config topic: the openMQTTGateway topic uses “device” (long format) and “ids” (short format). It seems that it should be either “device” and “identifiers” or “dev” and “ids”, but not mixed.
Would it be possible to add an item in the configuration of the gateway to use full labels or abbreviated labels, but not mix them? He is the list of abbreviations (search " Supported abbreviations in MQTT discovery messages" in this page):
