I got a bunch of DY-SQ100B from AliExpress and I tested with two units and saw something register as like Generic Remote and nothing matches what I read online. I bought these due them being recommended from the supported devices page.
I’m using a LilyGO v2.1 board running 433 of course and see other devices I have and even don’t have.
What do I need to do, test, or troubleshoot? Thanks!
They were supported before the integration of RTL_433, with RF gateway
This module uses an SRX882 or equivalent as a receiver, not an SX127X like you have
Not sure they can work with RTL_433, could you give more details like the messages you are getting from the detection?
So I was able to play more with the device and using OMG AutoDiscovery into HA it only comes through with the RSSI as a sensor. I know I can use templates in HA to give me the “last updated” time of the device and if that time is RECENT it is known the contacts connected. While this is a viable solution it is of course less than ideal.
