Hi there all,
I just search a lot of threads in the forum in order to find some sensor
that can be made by DIY and not to buy it.
But some little thinks that I found is not what I’m looing for.
So even if I’m newbe… I want to try to make a DIY sensor
that can be used with 2 X 1.5V batts for one year or more.
The sensor I want make will be with:
- atmega328p based (maybe attiny if memory permit for e-link display)
- DHT22 sensor (or other if someone can advise me)
- an e-link display (maybe something like this one)
- RF433 MHz trasmiter module (but here I need help to choose)
- 2 X 1.5 V battery
- box make with 3D Printer in order to put it on the wall, when all will work
So is there someone that can help me to arrive to make a hardware like this ?
I need help to choose the RF hardware and the protocol that can communicate with OMG.
The RF module must be:
- compatible with OMG
- must transmit at last at 100 Mt. (cause I’ll use some in the garden also)
- must have little current consume
- and must have little cost if possible
When all this will work, I’ll need to make at last 8 pieces.
So I must make all functional and nice
Thanks all
Denis
