Hi! Great software, much appreciated!
Board: LILYGO® TTGO LoRa32 V2.1_1.6 Version 433
Firmware: lilygo-rtl_433 v 1.7.0 fsk
I’m trying to figure out how to receive my weather station data… I got it working by using “fsk” version, but really well. With normal version it wasn’t visible at all.
I can see the Emax-W6 in Linux + SDR + RTL433 software, but really seldomly in OMG? HA get readings maybe every 5 minutes, via SDR each minute.
What are those "V: [ WebUI ] unhandled topic RFtoMQTT" in the console?
Here’s the console from WebUI (with verbose level):
V: [ WebUI ] unhandled topic WebUItoMQTT
T: Enqueue JSON
T: Queue length: 1
T: Enqueue JSON
T: Queue length: 2
N: Send on /RFtoMQTT msg {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-108,"avgrssi":-111,"count":31,"ookthreshold":15}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-108,"avgrssi":-111,"count":31,"ookthreshold":15}
T: Enqueue JSON
T: Queue length: 3
T: Dequeue JSON
N: Send on /SYStoMQTT msg {"uptime":1051,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113524,"mqttp":"1883","mqtts":false,"msgprc":32,"msgblck":0,"maxq":3,"minmem":44632,"tempc":48.89,"freestck":524,"eth":false,"rssi":-54,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":1051,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113524,"mqttp":"1883","mqtts":false,"msgprc":32,"msgblck":0,"maxq":3,"minmem":44632,"tempc":48.89,"freestck":524,"eth":false,"rssi":-54,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
N: Send on /SSD1306toMQTT msg {"onstate":true,"brightness":50,"display-flip":true,"idlelogo":true,"log-oled":false,"json-oled":true}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/SSD1306toMQTT msg: {"onstate":true,"brightness":50,"display-flip":true,"idlelogo":true,"log-oled":false,"json-oled":true}
V: [ WebUI ] unhandled topic SSD1306toMQTT
T: Dequeue JSON
N: Send on /WebUItoMQTT msg {"displayMetric":true,"webUISecure":true,"displayQueue":0}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/WebUItoMQTT msg: {"displayMetric":true,"webUISecure":true,"displayQueue":0}
T: isAdupl?
T: Enqueue JSON
T: Queue length: 1
T: Min ind: 5
T: store code : 1964 / 1120658
T: Col: val/timestamp
T: mem code : 1964 / 250666
T: mem code : 1964 / 340665
T: mem code : 1964 / 430664
T: mem code : 1965 / 790661
T: mem code : 1965 / 910660
T: mem code : 1964 / 1120658
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: Dequeue JSON
N: Send on /RTL_433toMQTT/Emax-W6/4/1960 msg {"model":"Emax-W6","id":1960,"channel":4,"battery_ok":1,"temperature_C":4.38889,"humidity":69,"wind_avg_km_h":0,"wind_dir_deg":313,"rain_mm":1.4,"uv":6,"light_lux":0,"mic":"CHECKSUM","protocol":"Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor","rssi":-53,"duration":116447}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/RTL_433toMQTT/Emax-W6/4/1960 msg: {"model":"Emax-W6","id":1960,"channel":4,"battery_ok":1,"temperature_C":4.38889,"humidity":69,"wind_avg_km_h":0,"wind_dir_deg":313,"rain_mm":1.4,"uv":6,"light_lux":0,"mic":"CHECKSUM","protocol":"Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor","rssi":-53,"duration":116447}
T: isAdupl?
T: Enqueue JSON
T: Queue length: 1
T: Min ind: 6
T: store code : 1964 / 1150659
T: mem code : 1964 / 1150659
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: mem code : 0 / 0
T: Dequeue JSON
N: Send on /RTL_433toMQTT/Emax-W6/4/1960 msg {"model":"Emax-W6","id":1960,"channel":4,"battery_ok":1,"temperature_C":4.38889,"humidity":69,"wind_avg_km_h":0,"wind_dir_deg":310,"rain_mm":1.4,"uv":6,"light_lux":0,"mic":"CHECKSUM","protocol":"Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor","rssi":-53,"duration":117004}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/RTL_433toMQTT/Emax-W6/4/1960 msg: {"model":"Emax-W6","id":1960,"channel":4,"battery_ok":1,"temperature_C":4.38889,"humidity":69,"wind_avg_km_h":0,"wind_dir_deg":310,"rain_mm":1.4,"uv":6,"light_lux":0,"mic":"CHECKSUM","protocol":"Emax W6, rebrand Altronics x7063/4, Optex 990040/50/51, Orium 13093/13123, Infactory FWS-1200, Newentor Q9, Otio 810025, Protmex PT3390A, Jula Marquant 014331/32, Weather Station or temperature/humidity sensor","rssi":-53,"duration":117004}
T: Enqueue JSON
T: Queue length: 1
T: Enqueue JSON
T: Queue length: 2
N: Send on /RFtoMQTT msg {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-114,"avgrssi":-111,"count":35,"ookthreshold":15}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-114,"avgrssi":-111,"count":35,"ookthreshold":15}
T: Enqueue JSON
T: Queue length: 3
T: Dequeue JSON
N: Send on /SYStoMQTT msg {"uptime":1171,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113524,"mqttp":"1883","mqtts":false,"msgprc":37,"msgblck":0,"maxq":3,"minmem":44616,"tempc":48.89,"freestck":524,"eth":false,"rssi":-55,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":1171,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113524,"mqttp":"1883","mqtts":false,"msgprc":37,"msgblck":0,"maxq":3,"minmem":44616,"tempc":48.89,"freestck":524,"eth":false,"rssi":-55,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
T: jsonPubl - ON
T: Dequeue JSON
T: jsonPubl - ON
T: Enqueue JSON
T: Queue length: 1
T: Enqueue JSON
T: Queue length: 2
N: Send on /RFtoMQTT msg {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-113,"avgrssi":-111,"count":39,"ookthreshold":15}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/RFtoMQTT msg: {"active":3,"frequency":433.92,"rssithreshold":-102,"rssi":-113,"avgrssi":-111,"count":39,"ookthreshold":15}
T: Enqueue JSON
T: Queue length: 3
T: Dequeue JSON
N: Send on /SYStoMQTT msg {"uptime":1291,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113536,"mqttp":"1883","mqtts":false,"msgprc":40,"msgblck":0,"maxq":3,"minmem":44616,"tempc":48.89,"freestck":524,"eth":false,"rssi":-53,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: jsonPubl - ON
T: [ OMG->MQTT ] topic: home/OMG_lilygo_rtl_433_ESP/SYStoMQTT msg: {"uptime":1291,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"lilygo-rtl_433-fsk","freemem":113536,"mqttp":"1883","mqtts":false,"msgprc":40,"msgblck":0,"maxq":3,"minmem":44616,"tempc":48.89,"freestck":524,"eth":false,"rssi":-53,"SSID":"Gugelby","BSSID":"48:22:54:39:57:CE","ip":"192.168.1.142","mac":"10:06:1C:08:31:90","modules":["LilyGo_SSD1306","WebUI","rtl_433"]}
T: Dequeue JSON
T: jsonPubl - ON
T: Dequeue JSON
T: jsonPubl - ON
Does it crash in between or what’s going on?
