My IBS-TH2 is posting temperatures in the thousands (F) when temperature falls below ~ 20 degrees F. However, the app is indicating the correct temperature. This is a repeatable issue where I can duplicate the results. Screenshots to help.
This has been corrected 8h ago on the dev branch ![]()
Ha… fixed before asked…
Thank you for this project and your work on it.
Would you mind posting an ESP32dev binary for the dev branch? I always have difficulties with Arduino IDE. It’s throwing me a missing decoder.h error when trying to compile the code.
You need to add this library to your library folder GitHub - theengs/decoder: Efficient, portable and lightweight library for Internet of Things messages decoding.
Ok… I’m past the library issue. Now I have this error.
exit status 1
‘StaticJsonDocument’ does not name a type
I’m sorry for these issues, my experience level isn’t sufficient to resolve this on my own.
No problem, here is the list of libraries that you need to have:
I still get the same error below. I’ve tried 2 different PCs and refreshing all the libararies, inlcuded the Decoder and Arduino-Log.
And here is this library list I have loaded.
LoRa
LowPower_LowPowerLab
NewRemoteSwitch
NimBLE-Arduino
OneWire
PubSubClient
rc-switch
RFM69
SmartRC-CC1101-Driver-Lib
SparkFun_BME280
SparkFun_HTU21D_Humidity_and_Temperature_Sensor_Breakout
SparkFun_SHTC3_Humidity_and_Temperature_Sensor_Library
SPIFlash
WeatherStationDataRx
WifiManager
Adafruit_AHTX0
Adafruit_BusIO
Adafruit_TSL2561
Adafruit_Unified_Sensor
arduino_36664
Arduino-INA226
ArduinoJson
Arduino-Log-master
DallasTemperature
decoder-development
DHT_sensor_library
FastLED
Infrared
IRremoteESP8266
Error
Arduino: 1.8.16 (Windows 10), Board: "ESP32 Dev Module, Disabled, Minimal SPIFFS (1.9MB APP with OTA/190KB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
main:58:1: error: 'StaticJsonDocument' does not name a type
StaticJsonDocument<JSON_MSG_BUFFER> modulesBuffer;
main:59:21: error: 'modulesBuffer' was not declared in this scope
JsonArray modules = modulesBuffer.to<JsonArray>();
main:59:47: error: expected primary-expression before '>' token
main:59:49: error: expected primary-expression before ')' token
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void pub(const char*, ArduinoJson::JsonObject&)':
main:312:35: error: 'serializeJson' was not declared in this scope
serializeJson(data, dataAsString);
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void pub_custom_topic(const char*, ArduinoJson::JsonObject&, boolean)':
main:380:29: error: 'serializeJson' was not declared in this scope
serializeJson(data, buffer);
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void setup()':
main:824:55: error: 'measureJson' was not declared in this scope
serializeJson(modules, jsonChar, measureJson(modules) + 1);
main:824:60: error: 'serializeJson' was not declared in this scope
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void saveMqttConfig()':
main:1047:3: error: 'DynamicJsonDocument' was not declared in this scope
DynamicJsonDocument json(512 + ota_server_cert.length() + mqtt_cert.length());
main:1048:3: error: 'json' was not declared in this scope
json["mqtt_server"] = mqtt_server;
main:1064:35: error: 'serializeJsonPretty' was not declared in this scope
serializeJsonPretty(json, Serial);
main:1065:33: error: 'serializeJson' was not declared in this scope
serializeJson(json, configFile);
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void setup_wifimanager(bool)':
main:1096:7: error: 'DynamicJsonDocument' was not declared in this scope
DynamicJsonDocument json(configFile.size() * 2);
main:1097:36: error: 'json' was not declared in this scope
auto error = deserializeJson(json, configFile);
main:1097:52: error: 'deserializeJson' was not declared in this scope
main:1101:39: error: 'serializeJsonPretty' was not declared in this scope
main:1115:55: error: expected primary-expression before 'bool'
mqtt_secure = json["mqtt_broker_secure"].as<bool>();
main:1117:51: error: expected primary-expression before 'const'
mqtt_cert = json["mqtt_broker_cert"].as<const char*>();
main:1119:59: error: expected primary-expression before '>' token
mqtt_ss_index = json["mqtt_ss_index"].as<uint8_t>();
main:1119:61: error: expected primary-expression before ')' token
main:1123:56: error: expected primary-expression before 'const'
ota_server_cert = json["ota_server_cert"].as<const char*>();
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void stateMeasures()':
main:1524:3: error: 'StaticJsonDocument' was not declared in this scope
StaticJsonDocument<JSON_MSG_BUFFER> jsonBuffer;
main:1524:39: error: 'jsonBuffer' was not declared in this scope
main:1525:48: error: expected primary-expression before '>' token
JsonObject SYSdata = jsonBuffer.to<JsonObject>();
main:1525:50: error: expected primary-expression before ')' token
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino: In function 'void receivingMQTT(char*, char*)':
main:1657:3: error: 'StaticJsonDocument' was not declared in this scope
main:1657:39: error: 'jsonBuffer' was not declared in this scope
main:1658:49: error: expected primary-expression before '>' token
JsonObject jsondata = jsonBuffer.to<JsonObject>();
main:1658:51: error: expected primary-expression before ')' token
main:1659:56: error: 'deserializeJson' was not declared in this scope
auto error = deserializeJson(jsonBuffer, datacallback);
main:1674:17: error: 'class ArduinoJson::JsonObject' has no member named 'isNull'
if (!jsondata.isNull()) { // json object ok -> json decoding
main:1677:35: error: 'serializeJson' was not declared in this scope
serializeJson(jsondata, buffer);
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBLEConnect.ino: In member function 'virtual bool zBLEConnect::processActions(std::vector<BLEAction>&)':
ZgatewayBLEConnect:83:48: error: use of deleted function 'ArduinoJson::JsonObject::JsonObject(const ArduinoJson::JsonObject&)'
JsonObject BLEresult = getBTJsonObject();
In file included from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson.hpp:11:0,
from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson.h:9,
from C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\main.ino:52:
C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/JsonObject.hpp:40:7: note: 'ArduinoJson::JsonObject::JsonObject(const ArduinoJson::JsonObject&)' is implicitly deleted because the default definition would be ill-formed:
class JsonObject : public Internals::JsonPrintable<JsonObject>,
In file included from c:\users\JA\documents\arduino\libraries\arduinojson\src\arduinojson\jsonbuffer.hpp:11:0,
from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Deserialization/JsonParser.hpp:7,
from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/JsonBufferBase.hpp:7,
from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/DynamicJsonBuffer.hpp:7,
from C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson.hpp:9,
C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Data/NonCopyable.hpp:17:3: error: 'ArduinoJson::Internals::NonCopyable::NonCopyable(const ArduinoJson::Internals::NonCopyable&)' is private
NonCopyable(const NonCopyable&);
C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/JsonObject.hpp:40:7: error: within this context
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBLEConnect.ino: In member function 'void LYWSD03MMC_connect::notifyCB(NimBLERemoteCharacteristic*, uint8_t*, size_t, bool)':
ZgatewayBLEConnect:140:44: error: use of deleted function 'ArduinoJson::JsonObject::JsonObject(const ArduinoJson::JsonObject&)'
JsonObject BLEdata = getBTJsonObject();
In file included from C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBT.ino:56:0:
C:\Users\JA\Documents\Arduino\libraries\decoder-development\src/decoder.h: At global scope:
decoder.h:40:22: error: 'JsonDocument' has not been declared
int getTheengModel(JsonDocument& doc, const char* model_id);
ZgatewayBT:108:3: error: 'StaticJsonDocument' does not name a type
StaticJsonDocument<JSON_MSG_BUFFER> buffer;
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBT.ino: In member function 'ArduinoJson::JsonObject& JsonBundle::createObject(const char*, bool)':
ZgatewayBT:113:5: error: 'buffer' was not declared in this scope
buffer.clear();
ZgatewayBT:115:34: error: expected primary-expression before '>' token
object = buffer.to<JsonObject>();
ZgatewayBT:115:36: error: expected primary-expression before ')' token
ZgatewayBT:118:48: error: 'deserializeJson' was not declared in this scope
auto error = deserializeJson(buffer, json);
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBT.ino: At global scope:
ZgatewayBT:135:41: error: use of deleted function 'JsonBundle::JsonBundle()'
JsonBundle jsonBTBufferQueue[BTQueueSize];
C:\Users\JA\Documents\Arduino\RFM_MQTT_GW_25.4_dev\main\ZgatewayBT.ino:106:7: note: 'JsonBundle::JsonBundle()' is implicitly deleted because the default definition would be ill-formed:
class JsonBundle {
ZgatewayBT:106:7: error: no matching function for call to 'ArduinoJson::JsonObject::JsonObject()'
C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/JsonObject.hpp:49:12: note: candidate: ArduinoJson::JsonObject::JsonObject(ArduinoJson::JsonBuffer*)
explicit JsonObject(JsonBuffer* buffer) throw()
C:\Users\JA\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/JsonObject.hpp:49:12: note: candidate expects 1 argument, 0 provided
Multiple libraries were found for "WiFi.h"
Used: C:\Users\JA\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
A beta is in production, should be ready in 1h there:
FYI. No action needed.
IBS-TH2 properly reporting Fahrenheit with OpenMQTTGateway v0.9.9beta
