Can’t compile 0.9.2 for nodemcu
Error log :
Executing task: platformio.exe run <
Processing nodemcuv2-rf (platform: espressif8266@1.8.0; board: nodemcuv2; framework: arduino)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 8266 1.8.0 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES: toolchain-xtensa 1.40802.0 (4.8.2), tool-esptool 1.413.0 (4.13), framework-arduinoespressif8266 2.20402.4 (2.4.2)
Converting main.ino
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 32 compatible libraries
Scanning dependencies…
Dependency Graph
|-- 2.7
|-- 5.13.4
|-- 1.0.0 #c3ff582
| |-- 1.0
| | |-- 1.0
| |-- 1.0
| | |-- 1.0
| |-- 1.1.0
| | |-- 1.0
|-- 2.6.2 #90adb34
|-- <esp8266_mdns>
| |-- 1.0
|-- 1.1.0
| |-- 1.0
|-- 0.16.0
|-- 1.0
| | |-- 1.0
| |-- 1.0
|-- 1.0
| |-- 1.0
|-- 1.0
|-- 3.4.1
|-- <Ethernet(esp8266)> 1.0.4
| |-- 1.0
|-- 1.0
| |-- 1.0
|-- 1.0
|-- 1.0
Compiling .pio\build\nodemcuv2-rf\src\main.ino.cpp.o
Generating LD script .pio\build\nodemcuv2-rf\ld\eagle.app.v6.common.ld
Compiling .pio\build\nodemcuv2-rf\lib8cc\PubSubClient_ID89\PubSubClient.cpp.o
C:/Temp/OpenMQTTGateway-nodemcu/main/ZgatewayRF2.ino:40:34: fatal error: NewRemoteTransmitter.h: No such file or directory
- Looking for NewRemoteTransmitter.h dependency? Check our library registry!
- CLI > platformio lib search “header:NewRemoteTransmitter.h”
- Web > https://platformio.org/lib/search?query=header:NewRemoteTransmitter.h
#include <NewRemoteTransmitter.h>
compilation terminated.
*** [.pio\build\nodemcuv2-rf\src\main.ino.cpp.o] Error 1
============================================================================================== [FAILED] Took 13.25 seconds ==============================================================================================
Environment Status Duration
rfbridge IGNORED
esp32dev-all IGNORED
esp32dev-rf IGNORED
esp32dev-ir IGNORED
esp32dev-ble IGNORED
ttgo-lora32-v1 IGNORED
nodemcuv2-all IGNORED
nodemcuv2-ble IGNORED
nodemcuv2-ir IGNORED
nodemcuv2-rf FAILED 00:00:13.252
atmega-all IGNORED
uno-rf IGNORED
uno-fastled IGNORED
========================================================================================= 1 failed, 0 succeeded in 00:00:13.252 =========================================================================================
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
returns 0 results
Investigated a little more :
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; Redirecting...
[platformio]
src_dir = main
; ENVIRONMENT CHOICE ;
;Uncomment the env line corresponding to your board and modules required, ;
;you can also adapt the modules by removing the corresponding lines in the env detail ;
;default_envs = rfbridge
;default_envs = esp32dev-all
;default_envs = esp32dev-rf
;default_envs = esp32dev-ir
;default_envs = esp32dev-ble
;default_envs = ttgo-lora32-v1
default_envs = nodemcuv2-rf
;default_envs = nodemcuv2-ir
;default_envs = nodemcuv2-ble
;default_envs = nodemcuv2-all
;default_envs = uno-rf
;default_envs = uno-fastled
;default_envs = atmega-all
; ENVIRONMENTS PARAMETERS ;
;Libraries and parameters shared accross environements ;
[libraries]
arduinojson = ArduinoJson@5.13.4
pubsubclient = PubSubClient@2.7
rc-switch = 1technophile/rc-switch#90adb34
newremoteswitch = 1technophile/NewRemoteSwitch#8eb980e
ble = eos1d3/ESP32_BLE#9d6c1ed
irremoteesp = IRremoteESP8266@2.6.3
irremote = IRremote
lora = sandeepmistry/arduino-LoRa#f4a1d27
esppilight = ESPiLight@0.16.0
rfm69 = RFM69@4a6f77ad47
dht = DHT sensor library@1.3.0
unifiedsensor = Adafruit Unified Sensor@1.0.2
tsl2561 = Adafruit TSL2561@1.0.3
bme280 = SparkFun BME280@2.0.4
bmp180 = BMP180@efac46bd8d
ina226 = jarzebski/Arduino-INA226#968a684
a6lib = 1technophile/A6lib
wifimanager = tzapu/WiFiManager#c3ff582
ethernet = Ethernet
esp8266_mdns = esp8266_mdns
wire = Wire
fastled = FastLED
[env]
framework = arduino
${libraries.pubsubclient}
${libraries.arduinojson}
-w ; supress all warnings
‘-DjsonPublishing=true’
‘-DjsonReceiving=true’
monitor_speed = 115200
[com]
esp8266_platform = espressif8266@1.8.0 ; 2.4.2
esp32_platform = espressif32@1.9.0
atmelavr_platform = atmelavr@1.13.0
[com-esp]
${env.lib_deps}
${libraries.wifimanager}
${env.build_flags}
-DMQTT_MAX_PACKET_SIZE=1024
‘-DsimpleReceiving=true’
‘-DsimplePublishing=true’
‘-DZmqttDiscovery=“HADiscovery”’
‘-DTRACE=1’
[com-arduino]
${env.lib_deps}
${libraries.ethernet}
${env.build_flags}
‘-DTRACE=1’
[com-arduino-low-memory]
${env.lib_deps}
${env.build_flags}
-DMQTT_MAX_PACKET_SIZE=128
; ENVIRONMENTS LIST ;
;List of environments that can be build ;
[env:rfbridge]
board = esp8285
${libraries.esp8266_mdns}
‘-DZgatewaySRFB=“SRFB”’
‘-DGateway_Name=“OpenMQTTGateway_SRFB”’
board_build.flash_mode = dout
[env:esp32dev-all]
board = esp32dev
${libraries.ble}
${libraries.irremoteesp}
${libraries.lora}
${libraries.rfm69}
${libraries.rc-switch}
${libraries.newremoteswitch}
${libraries.bme280}
${libraries.bmp180}
${libraries.unifiedsensor}
${libraries.dht}
${libraries.tsl2561}
${libraries.ina226}
${libraries.fastled}
‘-DZgatewayRF=“RF”’
‘-DZgatewayLORA=“LORA”’
‘-DZgatewayRF2=“RF2”’
‘-DZgatewayIR=“IR”’
‘-DZgatewayBT=“BT”’
‘-DZactuatorONOFF=“ONOFF”’
‘-DZactuatorFASTLED=“FASTLED”’
‘-DZsensorINA226=“INA226”’
‘-DZsensorHCSR501=“HCSR501”’
‘-DZsensorADC=“ADC”’
‘-DZsensorBH1750=“BH1750”’
‘-DZsensorBME280=“BME280”’
‘-DZsensorTSL2561=“TSL2561”’
‘-DZsensorDHT=“DHT”’
‘-DZgatewayRFM69=“RFM69”’
‘-DZsensorGPIOInput=“GPIOInput”’
‘-DZsensorGPIOKeyCode=“GPIOKeyCode”’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_ALL”’
[env:esp32dev-rf]
board = esp32dev
‘-DZgatewayRF=“RF”’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_RF”’
[env:esp32dev-ir]
board = esp32dev
‘-DZgatewayIR=“IR”’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_IR”’
[env:esp32dev-ble]
board = esp32dev
${libraries.ble}
‘-DZgatewayBT=“BT”’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_BLE”’
[env:ttgo-lora32-v1]
board = ttgo-lora32-v1
${libraries.lora}
‘-DGateway_Name=“OpenMQTTGateway_ESP32_LORA”’
[env:nodemcuv2-all]
board = nodemcuv2
${libraries.esppilight}
${libraries.rfm69}
${libraries.a6lib}
${libraries.bme280}
${libraries.bmp180}
${libraries.dht}
${libraries.ina226}
${libraries.wire}
‘-DZgatewayRF=“RF”’
‘-DZgatewayIR=“IR”’
‘-DZgatewayBT=“BT”’
‘-DZgateway2G=“2G”’
‘-DZgatewayPilight=“Pilight”’
‘-DGateway_Name=“OpenMQTTGateway_ESP8266_ALL”’
[env:nodemcuv2-ble]
board = nodemcuv2
${libraries.wire}
‘-DZgatewayBT=“BT”’
‘-DGateway_Name=“OpenMQTTGateway_ESP8266_BLE”’
[env:nodemcuv2-ir]
board = nodemcuv2
‘-DZgatewayIR=“IR”’
‘-DGateway_Name=“OpenMQTTGateway_ESP8266_IR”’
[env:nodemcuv2-rf]
board = nodemcuv2
‘-DZgatewayRF=“RF”’
‘-DGateway_Name=“OpenMQTTGateway_ESP8266_RF”’
[env:atmega-all]
platform = ${com.atmelavr_platform}
board = megaatmega2560
${com-arduino.lib_deps}
${libraries.irremote}
${libraries.rfm69}
${libraries.bme280}
${libraries.bmp180}
${libraries.dht}
${libraries.a6lib}
${libraries.ina226}
${com-arduino.build_flags}
‘-DZgatewayRF=“RF”’
‘-DZgatewayRF=“RF315”’
‘-DZgatewayIR=“IR”’
;‘-DZgatewayBT=“BT”’
;‘-DZsensorGPIOKeyCode=“GPIOKeyCode”’
‘-DGateway_Name=“OpenMQTTGateway_ATMEGA_ALL”’
[env:uno-rf]
board = uno
${com-arduino-low-memory.build_flags}
‘-DZgatewayRF=“RF”’
‘-DGateway_Name=“OpenMQTTGateway_UNO_RF”’
[env:uno-fastled]
board = uno
;extra_configs =
; tests/*_env.ini
Should [env:nodemcuv2-rf] not include the line ${libraries.newremoteswitch} ?
