i am using an ESP32 DEVKIT V1 as you can see here: Link
I want to use it as an BLE gateway to connect my LYWSD03MMC temperatur and humidity sensors to MQTT and from that to openHAB. Additionally i want to connect a DHT22 to the board to measure temperature and humidity at the board as well.
I have downloaded the sourcecode of the latest release v.0.9.10 from github and edited the following lines in the platformio.ini file:
[env:esp32dev-ble]
board = esp32doit-devkit-v1
${libraries.wifimanager32}
${libraries.ble}
${libraries.decoder}
${libraries.dht}
${libraries.unifiedsensor}
‘-DZgatewayBT=“BT”’
‘-DLED_SEND_RECEIVE=2’
‘-DLED_SEND_RECEIVE_ON=0’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_BLE”’
‘-DZsensorDHT=“DHT”’
‘-DESPWifiManualSetup=true’
‘-Dwifi_ssid=“Mynet”’
‘-Dwifi_password=“Mypassword”’
‘-DMQTT_SECURE_DEFAULT=false’
‘-DMQTT_SERVER=“MyIP”’
‘-DMQTT_PORT=“1883”’
I uncommented the line:
default_envs = esp32dev-ble
above in the platformio.ini file as well. The remaining firmware is completely untouched.
If i compile and upload the code with platformio the software starts and prints the following lines at the beginning over the serial terminal:
N: WiFi ok with manual config credentials
N: BLE scans interval: 55555
N: minrssi: 100
N: Low Power Mode: 0
N: Reading DHT on pin: 16
N: OpenMQTTGateway modules: [“BT”,“DHT”]
The BLE connections and the MQTT connections seems to work properly but the DHT22 sensor can not be readed.
I get everytime the failure over the serial terminal:
E: Failed to read from DHT sensor!
The sensor and the ESP is functinonal, i checked booth together with a small testprogramm. I see some communication as well on the data pin of the DHT22 with an logic analyzer but it seems that the transfer stops too early.
Can somebody help me with my problem or do i configure the software the wrong way?
