Hi!.
I’m trying to install Theengs Gateway last version on
HA is installed on Raspberry Pi3 Model B with 1 GB RAM.
But , when I try to start TG, after few seconds, I receive this errors:
[17:50:37] INFO: Creating TheengsGateway configuration...
[17:50:46] INFO: Starting TheengsGateway...
Traceback (most recent call last):
File "/usr/lib/python3.9/runpy.py", line 188, in _run_module_as_main
mod_name, mod_spec, code = _get_module_details(mod_name, _Error)
File "/usr/lib/python3.9/runpy.py", line 147, in _get_module_details
return _get_module_details(pkg_main_name, error)
File "/usr/lib/python3.9/runpy.py", line 111, in _get_module_details
__import__(pkg_name)
File "/usr/local/lib/python3.9/dist-packages/TheengsGateway/__init__.py", line 26, in <module>
from .ble_gateway import run
File "/usr/local/lib/python3.9/dist-packages/TheengsGateway/ble_gateway.py", line 51, in <module>
from bleak.backends.bluezdbus.advertisement_monitor import OrPattern
File "/usr/local/lib/python3.9/dist-packages/bleak/backends/bluezdbus/advertisement_monitor.py", line 12, in <module>
from dbus_fast.service import ServiceInterface, dbus_property, method, PropertyAccess
File "/usr/local/lib/python3.9/dist-packages/dbus_fast/__init__.py", line 1, in <module>
from . import introspection, message_bus, proxy_object, service
File "/usr/local/lib/python3.9/dist-packages/dbus_fast/introspection.py", line 5, in <module>
from .errors import InvalidIntrospectionError
File "/usr/local/lib/python3.9/dist-packages/dbus_fast/errors.py", line 57, in <module>
from .message import Message
File "src/dbus_fast/message.py", line 1, in init dbus_fast.message
ValueError: dbus_fast.signature.Variant size changed, may indicate binary incompatibility. Expected 48 from C header, got 40 from PyObject
Any idea?
Thanks in advance
