using vscode how do we declare the pins where the probes are connected
That really depends on which probe you are using and with which sensor module.
Then the pin assignments with their definitions are usually found in the .h files of the respective module, e. g. for ZsensorDHT.ino in config_DHT.h.
Did you include the ZsensorDS1820 module in your custom environment? By adding the lib_dep
${libraries.dallastemperature}
and the build_flag
'-DZsensorDS1820="DS1820"'
I don’t understand how to eclare a probe
Is it a DS1820 which you want to attach to you ESP32?
yes it’s definitely a dh1820
Then all you really need to do is set up your own custom environment, best in a portable config file, where you add the above lib_dep and build_flag to the environment, and hook up the DS1820 according to the pin assignments in config_DS1820.h. This should then automatically give you the MQTT messages in the interval DS1820_INTERVAL_SEC as described at
