Well… It ended working after few hours …I’ll attach it to the serial to see what’s going on …I changed the line to restart the esp … But unfortunately no luck
Yes if you can catch what’s going on with serial it will help.
Using arduino esp32 v1 is not recommended. Please refer to the wiki instructions to take the good esp32 arduino revision.
Hi! I’m experimenting same problems posted above. It could be great if a stable binary version can be uploaded in the repo (even thought ESP32 is still a dev environment)
Hi, unfortunately if i upload a binary version of esp32 we will have an issue with wifi and mqtt credentials…
We need first to integrate a wifimanager version compatible with esp32 to enable to enter credentials at runtime instead buildtime.
