Esp32 Arduino Stable Release V1
ExpressIf just released a stable esp32 v1 on github, I tried using it to compile and upload it to Esp32 chip and use it as BT Gateway and it works perfectly. Let me know if everything else works too.
Here is a installation instruction
Installation instructions using Arduino IDE Boards Manager
Starting with 1.6.4, Arduino allows installation of third-party platform packages using Boards Manager. We have packages available for Windows, Mac OS, and Linux (32 and 64 bit).
Install the current upstream Arduino IDE at the 1.8 level or later. The current version is at the Arduino website.
Start Arduino and open Preferences window.
Enter https://dl.espressif.com/dl/package_esp32_index.json into Additional Board Manager URLs field. You can add multiple URLs, separating them with commas.
Open Boards Manager from Tools > Board menu and install esp32 platform (and don’t forget to select your ESP32 board from Tools > Board menu after installation).
Stable release link: https://dl.espressif.com/dl/package_esp32_index.json
Development release link: https://dl.espressif.com/dl/package_esp32_dev_index.json
Thanks for the info !
@subrodey, I also complied OMG with BT only using official esp32v1 code. But I’m noticing that gateway disconnect from mqtt broker after some time, varying from minutes to ~5h and then do not reconnect, esp restart is required. Do you observe similar behavior or your gateway works without problems?
Best regards,
I only ran it for 30mins or so just to check if it worked… I will have to check and get back to you.
I’ve made some more tests today.
I’ve started OMG and I’ve put uptime and freemem reported by OMG via mqtt on chart (with help of OpenHAB and influxdb/grafana combo). Green line represents uptime, red: freemem. Breaks in green line means gateway lost connection to mqtt broker or wifi. When green line starts from the 0 = restart.
After initial tests I discovered, that OMG is able to recover mqtt connection, but only 2-3 times and then OMG is not accessible, not responding to ping - only reset helps :wink:
So I hookup OMG ESP32 dev board to computer and logged serial output.
  1. Starting log:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.08.09 13:17:00 =~=~=~=~=~=~=~=~=~=~=~=
ets Jun  8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:952
load:0x40078000,len:6084
load:0x40080000,len:7936
entry 0x40080310
I (27) wifi: wifi driver task: 3ffdfb84, prio:23, stack:4096, core=0
I (118) wifi: wifi firmware version: 4fd6a2c
I (119) wifi: config NVS flash: enabled
I (121) wifi: config nano formating: disabled
I (135) wifi: Init dynamic tx buffer num: 32
I (135) wifi: Init data frame dynamic rx buffer num: 10
I (135) wifi: Init management frame dynamic rx buffer num: 10
I (139) wifi: Init static rx buffer size: 1600
I (144) wifi: Init static rx buffer num: 4
I (147) wifi: Init dynamic rx buffer num: 10
I (211) wifi: mode : sta (30:ae:a4:03:58:f0)
122: Connecting to
122: B51
I (344) wifi: n:1 1, o:1 0, ap:255 255, sta:1 1, prof:1
634: .
I (1077) wifi: state: init -> auth (b0)
I (1080) wifi: state: auth -> assoc (0)
I (1084) wifi: state: assoc -> run (10)
I (1096) wifi: connected with B51, channel 1
I (1100) wifi: pm start, type: 1
1134: .
1134: WiFi ok with manual config credentials
1134: OpenMQTTGateway mac:
1134: 30:AE:A4:03:58:F0
1134: OpenMQTTGateway ip:
1134: 2986453184
1139: 1883
1139: Connecting to MQTT by IP adress
1140: 192.168.1.1
2642: ZgatewayBT multicore ESP32 setup done
2642: BT Task running on core 0
5001: MQTT connection...
5010: Connected to broker
5012: Subscription OK to the subjects
18240: Get ManufacturerData
18240: u
18242: Get RSSI
18242: B51/OMG/BT/6827377DB72A/rssi -84
18278: Get RSSI
18278: B51/OMG/BT/3CBD3E6B6F5D/rssi -76
18396: Get ManufacturerData
18396: Ĺ•
18397: Get RSSI
18397: B51/OMG/BT/7515E591316B/rssi -83
18398: Get service data
18401: 0000000000000000000000000000000000000000
18401: Get service data UUID
18403: 0000fe9f-0000-1000-8000-00805f9b34fb
18408: Get ManufacturerData
18409:
18411: Get RSSI
18412: B51/OMG/BT/10E2ACB234AD/rssi -47
18865: Get ManufacturerData
18865: Ĺ•
18867: Get RSSI
18867: B51/OMG/BT/6606F6E27513/rssi -76
18868: Get service data
18871: 0000000000000000000000000000000000000000
18871: Get service data UUID
18872: 0000fe9f-0000-1000-8000-00805f9b34fb
19082: Get ManufacturerData
19082: Ĺ•
19083: Get RSSI
19083: B51/OMG/BT/41AC5AC8FE77/rssi -62
19084: Get service data
19087: 0000000000000000000000000000000000000000
19087: Get service data UUID
19089: 0000fe9f-0000-1000-8000-00805f9b34fb
20001: Uptime (s)
20001: 20
  1. First connection drop, but with “self” recovery:
1420071: Uptime (s)
1420071: 1420
1420071: Remaining memory
1420071: 17308
1420071: RSSI
1420071: -41
1420071: SSID
1420071: B51
1420071: Activated modules
1420074: BT
1429627: Get ManufacturerData
1429627:
1429629: Get RSSI
1429629: B51/OMG/BT/13CC97E2A9DB/rssi -49
1429638: Get RSSI
1429638: B51/OMG/BT/5D7F0E57DDB1/rssi -82
1429639: Get service data
1429641: 0000000000000000000000000000000000000000
1429641: Get service data UUID
1429643: 0000fe9f-0000-1000-8000-00805f9b34fb
1429672: Get ManufacturerData
1429672: u
1429673: Get RSSI
1429673: B51/OMG/BT/6827377DB72A/rssi -80
1429676: Get RSSI
1429677: B51/OMG/BT/6124C65A47C7/rssi -62
1429677: Get service data
1429680: 0000000000000000000000000000000000000000
1429682: Get service data UUID
1429686: 0000fe9f-0000-1000-8000-00805f9b34fb
1429691: Get RSSI
1429691: B51/OMG/BT/666EAA945696/rssi -65
1429696: Get service data
1429699: 0000000000000000000000000000000000000000
1429702: Get service data UUID
1429705: 0000fe9f-0000-1000-8000-00805f9b34fb
1429710: Get RSSI
1429710: B51/OMG/BT/3CBD3E6B6F5D/rssi -84
1431506: Get RSSI
1431506: B51/OMG/BT/4B6D9E87D4D6/rssi -90
1431507: Get service data
1431510: 0000000000000000000000000000000000000000
1431510: Get service data UUID
1431510: 0000fe9f-0000-1000-8000-00805f9b34fb
1435990: Get ManufacturerData
1435990: L
1435991: Get RSSI
1435991: B51/OMG/BT/4BD839E035EF/rssi -87
I (1439442) wifi: state: run -> auth (2c0)
I (1439442) wifi: pm stop, total sleep time: 646395822 us / 1438342207 us
I (1439442) wifi: n:1 0, o:1 1, ap:255 255, sta:1 1, prof:1
[W][WiFiGeneric.cpp:360] _eventCallback(): Reason: 2 - AUTH_EXPIRE
I (1143439495363)3 : wMifQiTT:  cstonatnee:ct iauonth.. .->
 init [E][WiFiClient.cpp:213] connect(): lwip_connect_r: 118
(01)4
39373I:  (fa14il39ed46, 4)rc w=i
fi14: 39f3l7u7s:h  2t
xq
1
43I9 (1374399: 4t69ry)  awigafii:n  sinto 5p s
sw
 txq
I (1439474) wifi: lmac stop hw txq
I (1439486) wifi: mode : sta (30:ae:a4:03:58:f0)
1439422: BT Task running on core 0
1444383: MQTT connection...
1444383: failed, rc=
1444384: -2
1444384: try again in 5s
1449384: MQTT connection...
1449384: failed, rc=
1449384: -2
1449384: try again in 5s
1454385: MQTT connection...
1454385: failed, rc=
1454385: -2
1454385: try again in 5s
1459386: MQTT connection...
1459386: failed, rc=
1459386: -2
1459386: try again in 5s
1464387: MQTT connection...
1464387: failed, rc=
1464387: -2
1464387: try again in 5s
1464623: BT Task running on core 0
1469388: MQTT connection...
1469388: failed, rc=
1469388: -2
1469388: try again in 5s
1474389: MQTT connection...
1474389: failed, rc=
1474389: -2
1474389: try again in 5s
1479390: MQTT connection...
1479390: failed, rc=
1479390: -2
1479390: try again in 5s
1484391: MQTT connection...
1484391: failed, rc=
1484391: -2
1484391: try again in 5s
1489392: MQTT connection...
1489392: failed, rc=
1489392: -2
1489392: try again in 5s
1489824: BT Task running on core 0
1494393: MQTT connection...
1494393: failed, rc=
1494393: -2
1494393: try again in 5s
1499394: MQTT connection...
1499394: failed, rc=
1499394: -2
1499394: try again in 5s
1504395: MQTT connection...
1504395: failed, rc=
1504395: -2
1504395: try again in 5s
1509396: MQTT connection...
1509396: failed, rc=
1509396: -2
1509396: try again in 5s
1514397: MQTT connection...
1514397: failed, rc=
1514397: -2
1514397: try again in 5s
1515025: BT Task running on core 0
1519398: MQTT connection...
1519398: failed, rc=
1519398: -2
1519398: try again in 5s
1524399: MQTT connection...
1524399: failed, rc=
1524399: -2
1524399: try again in 5s
1529400: MQTT connection...
1529400: failed, rc=
1529400: -2
1529400: try again in 5s
1534401: MQTT connection...
1534401: failed, rc=
1534401: -2
1534401: try again in 5s
1539402: MQTT connection...
1539402: failed, rc=
1539402: -2
1539402: try again in 5s
1540226: BT Task running on core 0
1544403: MQTT connection...
1544403: failed, rc=
1544403: -2
1544403: try again in 5s
1549404: MQTT connection...
1549404: failed, rc=
1549404: -2
1549404: try again in 5s
1554405: MQTT connection...
1554405: failed, rc=
1554405: -2
1554405: try again in 5s
1559406: MQTT connection...
1559406: failed, rc=
1559406: -2
1559407: try again in 5s
1564407: MQTT connection...
1564407: failed, rc=
1564407: -2
1564407: try again in 5s
1565427: BT Task running on core 0
1569408: MQTT connection...
1569408: failed, rc=
1569408: -2
1569408: try again in 5s
1574409: MQTT connection...
1574409: failed, rc=
1574409: -2
1574409: try again in 5s
1579410: MQTT connection...
1579410: failed, rc=
1579410: -2
1579410: try again in 5s
1584411: MQTT connection...
1584411: failed, rc=
1584411: -2
1584411: try again in 5s
1589412: MQTT connection...
1589412: failed, rc=
1589412: -2
1589412: try again in 5s
1590628: BT Task running on core 0
1594413: MQTT connection...
1594413: failed, rc=
1594413: -2
1594413: try again in 5s
1599414: MQTT connection...
1599414: failed, rc=
1599414: -2
1599414: try again in 5s
1604415: MQTT connection...
1604415: failed, rc=
1604415: -2
1604415: try again in 5s
1609416: MQTT connection...
1609416: failed, rc=
1609416: -2
1609416: try again in 5s
1614417: MQTT connection...
1614417: failed, rc=
1614417: -2
1614417: try again in 5s
1615829: BT Task running on core 0
1619418: MQTT connection...
1619418: failed, rc=
1619418: -2
1619418: try again in 5s
1624419: MQTT connection...
1624419: failed, rc=
1624419: -2
1624419: try again in 5s
1629420: MQTT connection...
1629420: failed, rc=
1629420: -2
1629420: try again in 5s
1634421: MQTT connection...
1634421: failed, rc=
1634421: -2
1634421: try again in 5s
1639422: MQTT connection...
1639422: failed, rc=
1639422: -2
1639422: try again in 5s
1641030: BT Task running on core 0
1644423: failed connecting to mqtt
1644433: Connecting to
1644433: B51
I (1644690) wifi: n:1 1, o:1 0, ap:255 255, sta:1 1, prof:1
1644980: .
I (1645423) wifi: state: init -> auth (b0)
I (1645426) wifi: state: auth -> assoc (0)
I (1645431) wifi: state: assoc -> run (10)
I (1645443) wifi: connected with B51, channel 1
I (1645447) wifi: pm start, type: 1
1645480: .
1645480: WiFi ok with manual config credentials
1645480: MQTT connection...
1645498: Connected to broker
1645501: Subscription OK to the subjects
1645501: Uptime (s)
1645501: 1645
1645501: Remaining memory
1645501: 13888
1645501: RSSI
1645502: -42
1645503: SSID
1645504: B51
1645505: Activated modules
1645508: BT
1656392: Get ManufacturerData
1656392: u
1656394: Get RSSI
1656394: B51/OMG/BT/6827377DB72A/rssi -79
1656456: Get RSSI
1656456: B51/OMG/BT/55C12B47F91D/rssi -90
1656457: Get service data
1656460: 0000000000000000000000000000000000000000
1656460: Get service data UUID
1656460: 0000fe9f-0000-1000-8000-00805f9b34fb
1656594: Get RSSI
1656594: B51/OMG/BT/3CBD3E6B6F5D/rssi -78
  1. Final connection drop and OMG freeze:
2494489: 0000fe95-0000-1000-8000-00805f9b34fb
2494493: Processing BLE device data
2494496: mi flora data reading
2494499: rest_data
2494501: 71209800385e58658d7cc40d091002bf00
2494505: 5
2494509: 191.00
2494511: 191
2497789: Get RSSI
2497789: B51/OMG/BT/7CDBA823065C/rssi -82
2497791: Get service data
2497794: 0000000000000000000000000000000000000000
2497794: Get service data UUID
2497795: 0000fe9f-0000-1000-8000-00805f9b34fb
2497920: BT Task running on core 0
2505544: Uptime (s)
2505544: 2505
2505544: Remaining memory
2505544: 16540
2505544: RSSI
2505544: -41
2505544: SSID
2505544: B51
2505544: Activated modules
2505547: BT
2513268: Get RSSI
2513269: B51/OMG/BT/7CDBA823065C/rssi -83
2513272: Get service data
2513275: 0000000000000000000000000000000000000000
2513275: Get service data UUID
2513275: 0000fe9f-0000-1000-8000-00805f9b34fb
2513278: Get ManufacturerData
2513279:
2513282: Get RSSI
2513283: B51/OMG/BT/35F6DFE4E1D8/rssi -63
2513288: Get RSSI
2513288: B51/OMG/BT/66ABED23A7DC/rssi -62
2513292: Get service data
2513296: 0000000000000000000000000000000000000000
2513298: Get service data UUID
2513301: 0000fe9f-0000-1000-8000-00805f9b34fb
2513328: Get RSSI
2513328: B51/OMG/BT/6C596315D743/rssi -66
2513329: Get service data
2513331: 0000000000000000000000000000000000000000
2513331: Get service data UUID
2513332: 0000fe9f-0000-1000-8000-00805f9b34fb
2513441: Get ManufacturerData
2513441: u
2513442: Get RSSI
2513442: B51/OMG/BT/6827377DB72A/rssi -81
2513714: Get RSSI
2513714: B51/OMG/BT/3CBD3E6B6F5D/rssi -78
2514247: Get RSSI
2514247: B51/OMG/BT/78BCBEFEEF2C/rssi -90
2514248: Get service data
2514251: 0000000000000000000000000000000000000000
2514252: Get service data UUID
2514252: 0000fe9f-0000-1000-8000-00805f9b34fb
Task watchdog got triggered. The following tasks did not reset the watchdog in time:
 - IDLE (CPU 0)
Tasks currently running:
CPU 0: wifi
CPU 1: loopTask
2525545: Uptime (s)
2525545: 2525
2525545: Remaining memory
2525545: 16480
2525545: RSSI
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
I’ve searched for last error and found related to this issue topic on espressif github repo:
There is a long interesting discussion, with a solution to add to main loop delay using vTaskDelay(10); function.
I added it to main loop after line 663:
result:
    #if defined(ESP8266) || defined(ESP32)
      vTaskDelay(10);
      stateMeasures();
    #endif
Currently, with this modification, OMG is running for 3h35mins without connection drop. It’s too early to say that this a solution. Will report tomorrow.
BTW, I’ve enabled multicore for ESP32 in my case.
I kept this on for 8 hours today… Went for work just returned and I found it to be workinng… Its reporting to the MQTT that its alive… However i notice that it might have taken 2 reboots in between. Having said that, its responding and there is no problem, beacons are detecting fine.
Thanks for checking and reporting.
My OMG has just hung, afer 3h40m.
BTW, do you have multicore enabled? I will compile with disabled, no more ideas for now :roll_eyes: …
13216428: Uptime (s)
13216428: 13216
13216429: Remaining memory
13216429: 17280
13216429: RSSI
13216429: -51
13216429: SSID
13216429: B51
13216430: Activated modules
13216433: BT
13224083: Get RSSI
13224083: B51/OMG/BT/3CBD3E6B6F5D/rssi -81
13224094: Get ManufacturerData
13224094: u
13224095: Get RSSI
13224095: B51/OMG/BT/6827377DB72A/rssi -77
13224184: Get ManufacturerData
13224184:
13224185: Get RSSI
13224185: B51/OMG/BT/22AE132F83F0/rssi -48
13224306: Get RSSI
13224307: B51/OMG/BT/74F43450A84B/rssi -67
13224307: Get service data
13224309: 0000000000000000000000000000000000000000
13224309: Get service data UUID
13224311: 0000fe9f-0000-1000-8000-00805f9b34fb
13224518: Get RSSI
13224518: B51/OMG/BT/674093E69B82/rssi -71
13224519: Get service data
13224521: 0000000000000000000000000000000000000000
13224521: Get service data UUID
13224523: 0000fe9f-0000-1000-8000-00805f9b34fb
13225337: Get RSSI
13225337: B51/OMG/BT/6B1861B84F9D/rssi -82
13225338: Get service data
13225340: 0000000000000000000000000000000000000000
13225340: Get service data UUID
13225342: 0000fe9f-0000-1000-8000-00805f9b34fb
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
13236436: Uptime (s)
13236436: 13236
13236437: Remaining memory
13236437: 15264
13236437: RSSI
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
I didn’t do any extra settings… Just uncommented other modules keeping the bt module only…
I also have only BT module enabled.
Multicore is enabled by default:
One noticeable difference after turning off multicore is increased freemem reported by OMG from 15k for multicore to around 27k for multicore disabled.
Another test in progress…
Could you point us the version of omg you are using ?
HI @1technophile
I’m running latest commit from github.
Compiling on Win10, Arduino 1.8.5, stock libraries (not from github repository), ESP32 devkit board V1 from DoIt.
Yesterday I reflashed ESP32 using unmodified code from github, only BT module, with and without multicore enabled. Results was pretty the same, OMG lost connection after ~30mins or so. I was not logging serial output, will do it today, but I do not expect different errors than Task watchdog got triggered. The following tasks did not reset the watchdog in time:
I have another ESP unit, but bare one (no dev board), will give it a try after soldering to some proto board to be able to flash it :slight_smile:
BTW, thanks @1technophile for great work!
Thanks for these detailled infos, it seems that other people are having this issue. Here is an issue to follow also :
I got all sorts of those problems with esp32. The last one being the gw disconnecting to the mqtt and reconnecting. A tcpdump showed something very strange: the mqtt sending a Fin (or Reset) packet and the gw trying to reconnect again. But I didn’t had time yet to investigate further.
I’m also reconsidering the use of esp32 as it seems that there’s a design/hardware flaw. If I understood correctly the esp32 use the same antenna/radio to both wifi and bluetooth, so if it’s scanning BT it can’t send/receive wifi?
Yes and thats very annoying that one has to take care while doing anything with bluetooth and wifi together. Kts pretty flawed otherwise a powerful hardware poorly implemented.
I have also problem with the esp32 board when BT is On.
The device is disconnect from the wifi after about 1 hour,
There is any solution for it?
Or maybe a different version of OMG?
one user added
ESP.restart()
where the reconnect is happening and doesnt’ have the issue after.
In my side I’m still trying to install esp32 official release with the arduino IDE and it is very slow…
Hi people…I also face the disconnect issue. Unfortunately I didn’t attach the esp to serial port to debig but it’s the same after a while it disconnects from the wifi …I’m running v0.8 with only bt enabled …where would I put ESP.restart()?
The code works perfectly so far beyond the disconnect issue which is annoying as it makes it unreliable an not really usable for my home automation needs …
I’ll attach it to serial port tonight to see what’s in the logs and will provide further details …this happened with all versions by the way
@thundergreen
try to replace line 406:
if (failureAttempt > 30) setup_wifi(); //DIRTY FIX ESP32
by
if (failureAttempt > 30) ESP.restart(); //DIRTY FIX ESP32
I’ll try that dirty fix and report back
Fir the moment everything works well … thanks don’t use serial port …just let it on USB to see …I’ll let it run till Sunday and will report back
