Hi there all,
I just receive the ESP32 module and I want to use it in order to receive this Xiaomi temp/humidity sensor.
But because all the world is go in the PlatformIo direction I just want to begin to use it also.
So sorry for the newbie question…
but what *.zip file I must dovnload from the OMG source please ?
I downloaded the esp32dev-ble-libraries.zip but I didn’t find the platformio.ini file inside.
Can some one indicate the right file please ?
Thanks all
Denis
The warning you can take note of, and then close for the time being.
How are you building your desired environment - which is esp32dev-ble I assume, from your original post? Did you follow
Did you get the errors during that build? Are you connected to the internet while building, so that the appropriate libraries can be downloaded for the environment build?
This is normal, as it is the command to build all environments, when no specific target is specified and targeted.
As I can see from your first screenshot you seem to have tried adding your own environment in the env list, though I’m not too sure of the syntax, or is it just a comment above the esp32dev-ble entry?
If you have made or want to make changes to the build settings it might be best to create them in a separate file, and take the prod_env.ini.example as a start, as also described further down on the Docs page
Instead of uncommenting and commenting back various env targets for different builds, also have a look on the left side of VSCode, and click on the platfomio icon. Under Project Tasks you will find all the various environments with individual Clean, Build, Upload etc. options for each.
