Hi guys,
I got 3 boards(2 ESP32 & 1 nodemcu) flashed OMG 0.9.6(uploaded from PlatformIO with some config modifications). several days ago I tried to flash 2 of them(1esp32 & nodemcu) with the new release 0.9.7 code base, after that I kept failing to send RF signal.
Have you guys encountered this problem? I’m aware of that the RCSwitch lib got an update with the 0.9.7 release, is it the cause?
My boards keep shutting down and restart( sometimes they don’t) with 0.9.6, so I want to try the 0.9.7 release.
With same wire connection, the Nodemcu board failed to send RF( I tested this by switch on/off my 433 RF light) with the 0.9.7 firmware( downloaded from the release page on github), while all things work well with the 0.9.6 firmware.
Here is the log output with the 0.9.7 firmware:
(null)(null)(null)(null)(null)(null){"mqtt_server":"ha.cn","mqtt_port":"1883","mqtt_user":"your_username","mqtt_pass":"your_password","mqtt_topic":"home/","gateway_name":"OpenMQTTGateway_ESP8266_RF"}*WM: [1] getCoreVersion(): 2_7_4
*WM: [1] system_get_sdk_version(): 2.2.2-dev(38a443e)
*WM: [1] system_get_boot_version(): 31
*WM: [1] getFreeHeap(): 41808
N: RF_EMITTER_GPIO: 3
N: RF_RECEIVER_GPIO: 0
N: Switching to RF Receiver
N: OpenMQTTGateway modules: ["RF"]
W: MQTT connection...
N: Connected to broker
N: Received json : ["RF"]
N: Subject: /SYStoMQTT
N: Received json : {"uptime":7,"version":"v0.9.7","freemem":35272,"rssi":-45,"SSID":"HOME","ip":"192.168.3.154","mac":"C4:5B:BE:6D:66:83","actRec":2,"modules":["RF"]}
N: Received json : {"value":1786498,"protocol":1,"length":24}
N: RF Protocol:1
N: RF Pulse Lgth: 350
N: Bits nb: 24
N: MQTTtoRF OK
N: Subject: /433toMQTT
N: Received json : {"value":16432257,"protocol":1,"length":24,"delay":300}
N: no pub. dupl
