ESP32-Pilight needs reboot
I have my ESP32 with Pilight up and running, for some reason it stops working after a while. If I reset the unit it starts working again. I have no logs atm but I can check on request whatever is needed to solve the problem.
It could be interesting if you can give a serial monitor output.
When you say a while you are talking about how much time ?
After a few hours it seems to work, but the next day it does not respond. I can set it up on friday log the serial port all day.
Did a test yesterday. Did not manage to reproduce it while logging for 12 hours. Probably it needs to run for a longer time. Maybe I will add a watchdog and see if that helps.
ok thanks for the feedback!
It seems to be working better. It has worked all week. :slight_smile:
