Morning,
yes, I checked the history with MQTT-Explorer. After starting the device there is one message with a random attribute per device. After that there are only battery messages.
[07:00:02]N: Scan begin
[07:00:02]N: Device detected: 20:00:FE:44:1C:F2
[07:00:02]N: Subject: /BTtoMQTT/2000FE441CF2
[07:00:02]N: Received json : {"id":"20:00:FE:44:1C:F2","rssi":-52}
[07:00:03]N: Device detected: 7D:32:8D:C4:03:D3
[07:00:03]N: Subject: /BTtoMQTT/7D328DC403D3
[07:00:03]N: Received json : {"id":"7D:32:8D:C4:03:D3","rssi":-75,"servicedata":"0ac2106ffbdc0733866a4c2dc0e4a21963e0783c"}
[07:00:03]N: Device detected: DF:5A:89:90:74:52
[07:00:03]N: Subject: /BTtoMQTT/DF5A89907452
[07:00:03]N: Received json : {"id":"DF:5A:89:90:74:52","name":"Mi Smart Band 5","manufacturerdata":"570102ffffffffffffffffffffffffffffffff02df5a89907452","rssi":-75,"model":"MIBAND","steps":61}
[07:00:04]N: Device detected: C4:7C:8D:6B:05:DE
[07:00:04]N: Filtered connectable device
[07:00:04]N: Device detected: C4:7C:8D:6A:EF:3C
[07:00:05]N: Device detected: 20:00:FE:44:1C:F2
[07:00:05]N: Subject: /BTtoMQTT/2000FE441CF2
[07:00:05]N: Received json : {"id":"20:00:FE:44:1C:F2","rssi":-53}
[07:00:05]N: Device detected: C4:7C:8D:6B:05:5F
[07:00:05]N: Filtered connectable device
[07:00:06]N: Device detected: 7D:32:8D:C4:03:D3
[07:00:06]N: Subject: /BTtoMQTT/7D328DC403D3
[07:00:06]N: Received json : {"id":"7D:32:8D:C4:03:D3","rssi":-77,"servicedata":"0ac2106ffbdc0733866a4c2dc0e4a21963e0783c"}
[07:00:07]N: Device detected: C4:7C:8D:6B:05:91
[07:00:07]N: Filtered connectable device
[07:00:10]N: Device detected: C4:7C:8D:6B:05:DE
[07:00:10]N: Filtered connectable device
[07:00:12]N: Found 7 devices, scan number 9 end
[07:01:08]N: Scan begin
[07:01:08]N: Device detected: 20:00:FE:44:1C:F2
[07:01:08]N: Subject: /BTtoMQTT/2000FE441CF2
[07:01:08]N: Received json : {"id":"20:00:FE:44:1C:F2","rssi":-52}
[07:01:08]N: Subject: /SYStoMQTT
[07:01:08]N: Received json : {"uptime":606,"version":"version_tag","freemem":110812,"freestack":3492,"rssi":-73,"SSID":"wifinetwork","ip":"192.168.XXX.XXX","mac":"8C:AA:B5:8C:XX:XX","lowpowermode":0,"btqblck":0,"btqsum":40,"btqsnd":40,"btqavg":1,"interval":55555,"scanbcnct":10,"scnct":9,"modules":["BT"]}
[07:01:09]N: Device detected: C4:7C:8D:6B:05:91
[07:01:09]N: Filtered connectable device
[07:01:09]N: Device detected: 7D:32:8D:C4:03:D3
[07:01:09]N: Subject: /BTtoMQTT/7D328DC403D3
[07:01:09]N: Received json : {"id":"7D:32:8D:C4:03:D3","rssi":-75,"servicedata":"0ac2106ffbdc0733866a4c2dc0e4a21963e0783c"}
[07:01:10]N: Device detected: C4:7C:8D:6B:05:DE
[07:01:10]N: Filtered connectable device
[07:01:10]N: Device detected: C4:7C:8D:6B:05:5F
[07:01:15]N: Device detected: DF:5A:89:90:74:52
[07:01:15]N: Subject: /BTtoMQTT/DF5A89907452
[07:01:15]N: Received json : {"id":"DF:5A:89:90:74:52","name":"Mi Smart Band 5","manufacturerdata":"570102ffffffffffffffffffffffffffffffff02df5a89907452","rssi":-69,"model":"MIBAND","steps":61}
[07:01:17]N: Device detected: C4:7C:8D:6A:EF:3C
[07:01:17]N: Filtered connectable device
[07:01:18]N: Found 7 devices, scan number 10 end
[07:01:18]N: BLE Connect begin
[07:01:20]N: Subject: /BTtoMQTT/C47C8D6B0591
[07:01:20]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:91","batt":47}
[07:01:22]N: Subject: /BTtoMQTT/C47C8D6B055F
[07:01:22]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:5F","batt":34}
[07:01:26]N: Subject: /BTtoMQTT/C47C8D6AEF3C
[07:01:26]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6A:EF:3C","batt":54}
[07:01:29]N: Subject: /BTtoMQTT/C47C8D6B05DE
[07:01:29]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:DE","batt":100}
[07:01:29]N: BLE Connect end
[07:16:25]ets Jun 8 2016 00:22:57
[07:16:25]
[07:16:25]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[07:16:25]configsip: 0, SPIWP:0xee
[07:16:25]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[07:16:25]mode:DIO, clock div:2
[07:16:25]load:0x3fff0018,len:4
[07:16:25]load:0x3fff001c,len:1044
[07:16:25]load:0x40078000,len:10124
[07:16:25]load:0x40080400,len:5828
[07:16:25]entry 0x400806a8
[07:16:26]N:
[07:16:26]************* WELCOME TO OpenMQTTGateway **************
[07:16:26]N: OpenMQTTGateway Version: version_tag
[07:16:28]N: WiFi ok with manual config credentials
[07:16:30]N: BLE scans interval: 55555
[07:16:30]N: BLE scans number before connect: 10
[07:16:30]N: Publishing only BLE sensors: false
[07:16:30]N: minrssi: 100
[07:16:30]N: Low Power Mode: 0
[07:16:30]N: OpenMQTTGateway modules: ["BT"]
[07:16:30]N: ************** Setup OpenMQTTGateway end **************
[07:16:30]W: MQTT connection...
[07:16:31]N: Connected to broker
[07:16:31]N: Received json : ["BT"]
[07:16:32]N: Received json : ["BT"]
[07:16:32]N: Subject: /SYStoMQTT
[07:16:32]N: Received json : {"uptime":5,"version":"version_tag","freemem":105744,"freestack":3500,"rssi":-76,"SSID":"wifinetwork","ip":"192.168.XXX.XXX","mac":"8C:AA:B5:8C:XX:XX","lowpowermode":0,"btqblck":0,"btqsum":0,"btqsnd":0,"btqavg":0,"interval":55555,"scanbcnct":10,"scnct":0,"modules":["BT"]}
[07:16:32]N: Scan begin
[07:16:32]N: Device detected: 71:80:B7:76:B7:17
[07:16:32]N: Subject: /BTtoMQTT/7180B776B717
[07:16:32]N: Received json : {"id":"71:80:B7:76:B7:17","rssi":-82,"servicedata":"de9a81143cd7079a09651ca36baa0ec585e0d2be"}
[07:16:32]N: Device detected: 0C:F0:1F:1C:8B:E6
[07:16:32]N: Subject: /BTtoMQTT/0CF01F1C8BE6
[07:16:32]N: Received json : {"id":"0C:F0:1F:1C:8B:E6","rssi":-38}
[07:16:32]N: Device detected: C4:7C:8D:6B:05:5F
[07:16:32]E: Semaphore NOT taken
[07:16:32]N: Subject: /BTtoMQTT/C47C8D6B055F
[07:16:32]N: Received json : {"id":"C4:7C:8D:6B:05:5F","name":"Flower care","rssi":-86,"model":"HHCCJCY01HHCC","tempc":23.9,"tempf":75.02}
[07:16:33]N: Device detected: C4:7C:8D:6B:05:DE
[07:16:33]E: Semaphore NOT taken
[07:16:33]N: Subject: /BTtoMQTT/C47C8D6B05DE
[07:16:33]N: Received json : {"id":"C4:7C:8D:6B:05:DE","name":"Flower care","rssi":-73,"model":"HHCCJCY01HHCC","fer":176}
[07:16:34]N: Device detected: C4:7C:8D:6A:EF:3C
[07:16:34]E: Semaphore NOT taken
[07:16:34]N: Subject: /BTtoMQTT/C47C8D6AEF3C
[07:16:34]N: Received json : {"id":"C4:7C:8D:6A:EF:3C","name":"Flower care","rssi":-80,"model":"HHCCJCY01HHCC","moi":7}
[07:16:36]N: Device detected: C4:7C:8D:6B:05:91
[07:16:36]E: Semaphore NOT taken
[07:16:36]N: Subject: /BTtoMQTT/C47C8D6B0591
[07:16:36]N: Received json : {"id":"C4:7C:8D:6B:05:91","name":"Flower care","rssi":-74,"model":"HHCCJCY01HHCC","moi":19}
[07:16:39]N: Device detected: DF:5A:89:90:74:52
[07:16:39]E: Semaphore NOT taken
[07:16:39]N: Subject: /BTtoMQTT/DF5A89907452
[07:16:39]N: Received json : {"id":"DF:5A:89:90:74:52","name":"Mi Smart Band 5","manufacturerdata":"570102ffffffffffffffffffffffffffffffff02df5a89907452","rssi":-45,"model":"MIBAND","steps":61}
[07:16:42]N: Found 7 devices, scan number 1 end
[07:16:42]N: BLE Connect begin
[07:16:45]N: Subject: /BTtoMQTT/C47C8D6B055F
[07:16:45]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:5F","batt":34}
[07:16:48]N: Subject: /BTtoMQTT/C47C8D6B05DE
[07:16:48]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:DE","batt":100}
[07:16:50]N: Subject: /BTtoMQTT/C47C8D6AEF3C
[07:16:50]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6A:EF:3C","batt":54}
[07:16:54]N: Subject: /BTtoMQTT/C47C8D6B0591
[07:16:54]N: Received json : {"model":"HHCCJCY01HHCC","id":"C4:7C:8D:6B:05:91","batt":47}
[07:16:54]N: BLE Connect end
