sleu
1
I have a brand new board (https://a.co/d/eVlfatA) using the current version of OMG.
I had noticed the reported uptime was low fairly often and I started watching it. I noticed when the reported RSSI changed, the board would restart.
I attached 2 screenshots that clearly show that interesting correlation.
The module wasn’t touched during any of that.
Sometimes it would restart within a few seconds, sometimes hours. But there is a clear correlation to the RSSI.
Any ideas? Advice?
It’s odd to get those frequent resets…
sleu
2
Wasn’t allowed to add both in my post so adding the zoomed in version here…
sleu
3
Watching the serial port I found this goodie…
Which environment/binary are you using?
sleu
5
I flashed the pre-built sw from here…
Running 1.6.0 esp32dev-ble-datatest
HW is a esp32-wroom board.
Do you have ever used PlatformIO to add TRACE and exception decoding to this? Here is an environment that would help with debugging:
[env:esp32dev-ble-datatest]
board = esp32dev
monitor_filters = esp32_exception_decoder
${com-esp32.lib_deps}
${libraries.ble}
${libraries.decoder}
${com-esp32.build_flags}
'-DZgatewayBT="BT"'
'-DLED_SEND_RECEIVE=2'
'-DLED_SEND_RECEIVE_ON=0'
'-DTimeBtwRead=0'
'-DScan_duration=3000'
'-DAttemptBLEConnect=false'
'-DpubBLEAdvData=true'
'-DGateway_Name="OMG_ESP32_BLE"'
'-DLOG_LEVEL=LOG_LEVEL_TRACE
Alternatively you could try also the latest dev branch
sleu
7
I’ll give this a try. All new to me so no, have not tried that before.
