I am trying to get OMG to work with an ESP8266 (NodeMcu v3 CH340) using a CC1101-transceiver (E07-M1101D). I want to be able to send/receive signals like my Elro AB440R-433.92MHz Remote, though I have also tried with some other 433Mhz devices I had lying around and none seem to be picked up - neither in MQTT nor in serial monitor (also when setting ‘’-DCORE_DEBUG_LEVEL=4’‘or "-DLOG_LEVEL=LOG_LEVEL_TRACE’). I verified the supplied voltage to be 3.3V.
My configuration.ini file looks like this:
[platformio]
default_envs = nodemcuv2-rf2-cc1101-custom
[env:nodemcuv2-rf2-cc1101-custom]
extends = env:nodemcuv2-rf2-cc1101
${env:nodemcuv2-rf2-cc1101.build_flags}
'-DZgatewayRF2="RF2"'
'-DGateway_Name="CC1101OMG_ESP8266_RF2-CC1101"'
'-DBase_Topic="CC1101/"'
'-DESPWifiManualSetup=true'
'-Dwifi_ssid="xxxxxx"'
'-Dwifi_password="xxxxx"
'-DMQTT_SERVER="192.168.2.100"' ; Connects fine
'-DRF_RECEIVER_GPIO=4' ;Receiver on D2 instead of D3 according to [the troubleshooting guide](https://docs.openmqttgateway.com/upload/troubleshoot.html#esp32-compilation-errors-related-to-wifi)
'-DZradioCC1101="CC1101"' ;Not sure if this is necessary?
'-DLOG_LEVEL=LOG_LEVEL_TRACE'
Pins are connected according to the OMG-Docs CC1101-pinout:
- GDO2 → D2 (After setting to D2/GPIO4 according to Troubleshooting guide)
- GDO0 → RX (Also tried on D1/GPIO5)
- SCK → D5
- VCC → 3V3
- MOSI → D7
- MISO → D6
- CSN → D8
- GND → GND
Is there something obvious I’m doing wrong? Even when my devices are unsupported, I should be able to see something when setting DLOG_LEVEL, right?
Any suggestions for further troubleshooting are more than welcome!
