My ESP8266 (Wifi Manager) doesn’t save the Wifi settings.
When I power it up I can configure it with the wifi manager and it works. But after pulling the cord and plugging it in again, I have to configure it again.
Two modules loaded: RF and ONOFF
I only tried pin D1 yet and I use SRX882 and STX882.
I have just tested it with a nodemcu v2 and a esp32 geekcreit and the parameters are well saved, the two boards reconnect automaticaly after a disconnection and a wait of 10s.
File "/Users/*user*/.platformio/penv/lib/python2.7/site-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/cu.wchusbserial-1410: [Errno 2] No such file or directory: '/dev/cu.wchusbserial-1410'
What am I doing wrong. I pressed the flash button at the nodemcu.
EDIT: I still don’t know whats wrong with that port connection, because it works with arduino ide. But I now flashed it with Platformio and my FTDI adapter.
EDIT2: Ok so after flashing it with the FTDI adapter and Platformio the gateway immediatly turned online again after restarting it.
If you know what’s the issue here, I would be glad if you tell me.
Maybe set the upload port like this for example :
upload_port = COM[5]
If you don’t indicate the upload port platformio should choose the one with a board or propose you a choice if several boards are connected.
I will enrich the examples of platformio.ini.
I made a modification on the development branch that should help with the issue about wifimanager not saving the credentials.
It was due to error on formating the esp file system.
However I have a new issue. With the newest dev version I can’t compile for the nodemcu any more. Still works for esp32.
/Users/user/Downloads/OpenMQTTGateway-development/main/main.ino: In function 'void setup_wifimanager(bool)':
/Users/user/Downloads/OpenMQTTGateway-development/main/main.ino:663:26: error: no matching function for call to 'fs::FS::begin(bool)'
if (SPIFFS.begin(true))
BTW: I noticed that there are different versions of the nodemcu out there. I have one with a CH340 chip. Seems like the one with a cp2102 chip would be better. Which one do you have?
Yes the build is broken for esp8266. Just remove the true inside the parenthesis to make it build. But you will see the same behaviour than before.
I think you need to set an spiffs to have the wifi parameters storage.
