ESP8266 + HM-10 start problem
Hello.
I have ESP8266 + HM-10.
I successfully downloaded the OpenMQTTGateway firmware on ESP8266. Start is OK, ESP connect with WiFi and MQTT broker:
WiFi ok with manual config credentials
OpenMQTTGateway mac:
B4:E6:2D:17:F7:F9
OpenMQTTGateway ip:
192.168.1.183
1883
192.168.1.67
ZgatewayBT HM1X setup done
MQTT_MAX_PACKET_SIZE
1024
Setup OpenMQTTGateway end
MQTT connection…
Connected to broker
I install iBeacon app from Google play on Android cell phone, set it up and run it - and I don’t see this Beacon, MQTT broker receives only this message:
home/OpenMQTTGateway/SYStoMQTT {“uptime”:120,“freeMem”:44960,“rssi”:-92,“SSID”:“gsens”,“modules”:“BT”}
For verification, I install on ESP8266 Serial In\Out firmware and type command AT+DISI?
Answer:
OK+DISISOK+DISC:4C000215:76F62353EEB44977A3310B5DCED842FE:00000000BF:7318847A04AA:-086OK+DISCE
where 76F62353EEB44977A3310B5DCED842FE is UUID my iBeacon on Android.
As I understand it, this means that the ESP8266 and HM-10 are working, everything is connected correctly.
What can I do wrong?
Thanks…
Did you checked the version of your hm10 firmware, and eventually upgraded it? You can do some google search so as to do that.
Hello!
I checked the version - HMSoft V605
Could you give the version of omg you are using ?
Did you wait at least 3 minutes to see if beacons appears ?
Version is 0.9beta
Yes, I wait a more than 3 minutes.
Should a message appear in the serial terminal after beacon is finding? Or I can see message only in MQTT topic?
PS: I view code and I see that message must appears…I’ll look at where in the code the data is not coming …
I found my mistake… I’m so sorry…
D6 to RX, D7 to TX… (…
All work fine ))
No problem, happy that it works
