Yes, the issue is reproducible, and the decoded message is the same.
Here is what I did:
- Checkout a new branch from the tag 0.9.8.
- Change the platform.ini like you wrote, then compile
- Flash the nodemcu(Lolin) with the firmware built at #2 by using NodeMCU PyFlasher(Mac OS version).
- Config wifi info & mqtt broker address(192.168.3.82) in wifimanager page.
- Start the Mqtt server at my Mac(192.168.3.82), and simulate “connection timeout” and “connect failed”
Decoded message:
Exception Cause: 28 [LoadProhibited: A load referenced a page mapped with an attribute that does not permit loads]
0x4020b5cf: BearSSL::WiFiClientSecure::getLastSSLError(char*, unsigned int) at ??:?
0x4020773e: PubSubClient::setBufferSize(unsigned short) at ??:?
0x40201f46: connectMQTT() at ??:?
0x40217070: Print::print(char) at ??:?
0x40216a24: HardwareSerial::write(unsigned char const*, unsigned int) at ??:?
0x40207b7c: Logging::print(__FlashStringHelper const*, __va_list_tag) at ??:?
0x40216e0d: Print::write(char const*) at ??:?
0x4027fb70: chip_v6_unset_chanfreq at ??:?
0x40201a8c: void Logging::printLevel<__FlashStringHelper const*>(int, __FlashStringHelper const*, ...) at ??:?
0x40224010: _ZN7esp826613polledTimeout15timeoutTemplateILb0ENS0_11YieldPolicy9DoNothingENS0_10TimePolicy8TimeUnitINS4_16TimeSourceMillisELy1000EEEE5resetEv$isra$15 at LEAmDNS_Control.cpp:?
0x40224a86: esp8266::MDNSImplementation::MDNSResponder::_updateProbeStatus() at ??:?
0x4022af40: base64_encode_value at ??:?
0x402255e9: esp8266::MDNSImplementation::MDNSResponder::_process(bool) at ??:?
0x4026d157: wifi_station_get_connect_status at ??:?
0x40223b22: esp8266::MDNSImplementation::MDNSResponder::update() at ??:?
0x40205140: loop at ??:?
0x402193c0: loop_wrapper() at core_esp8266_main.cpp:?
0x401013b9: cont_wrapper at ??:?
Here is part of the original serial output(only exceptions) with timestamp:
21:53:57.976 -> N: ************** Setup OpenMQTTGateway end **************
21:53:57.976 -> W: MQTT connection...
21:53:59.348 -> W: failure_number_mqtt: 1
21:53:59.348 -> W: failed, rc=-2
21:53:59.348 ->
21:53:59.348 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:53:59.348 ->
21:53:59.348 -> Exception (9):
21:53:59.348 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x00460046 depc=0x00000000
21:53:59.348 ->
21:53:59.348 -> >>>stack>>>
21:53:59.348 ->
21:53:59.348 -> ctx: cont
21:53:59.348 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:53:59.388 -> 3ffffe60: 00000001 00000000 00000001 4020773e
21:53:59.388 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:53:59.388 -> 3ffffe80: 00000001 3ffe88bf 3fff1894 40217070
21:53:59.388 -> 3ffffe90: 40216a24 3fff05f0 3ffe9476 40207b7c
21:53:59.388 -> 3ffffea0: 3ffffef0 3ffffee0 0000000c 40216e0d
21:53:59.388 -> 3ffffeb0: 4027fb70 3ffe9404 3fff0330 0000075b
21:53:59.388 -> 3ffffec0: 4027fb70 3ffe9404 3fff0330 40201a8c
21:53:59.388 -> 3ffffed0: 00000000 4bc6a7f0 00014120 00000001
21:53:59.423 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:53:59.423 -> 3ffffef0: 00000001 656d6f68 65704f2f 54514d6e
21:53:59.423 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:53:59.423 -> 3fffff10: 574c2f54 3fff0054 3fff13e4 40224010
21:53:59.423 -> 3fffff20: 4652225b 50222c22 3fff13ac 40224a86
21:53:59.423 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:53:59.423 -> 3fffff40: 00000000 4bc6a7f0 00014120 00000000
21:53:59.423 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:53:59.423 -> 3fffff60: 4026d157 feefeffe 3fff04c0 40223b22
21:53:59.459 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:53:59.459 -> 3fffff80: 3fff0034 3ffeffa8 00014120 40205140
21:53:59.459 -> 3fffff90: feefeffe feefeffe feefeffe 3fff0730
21:53:59.459 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:53:59.459 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:53:59.459 -> <<<stack<<<
21:53:59.459 ->
21:53:59.459 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:53:59.492 ->
21:53:59.492 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:54:01.364 -> N: ************** Setup OpenMQTTGateway end **************
21:54:01.364 -> W: MQTT connection...
21:54:01.399 -> W: failure_number_mqtt: 1
21:54:01.399 -> W: failed, rc=-2
21:54:01.399 ->
21:54:01.399 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:01.399 ->
21:54:01.399 -> Exception (28):
21:54:01.399 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
21:54:01.399 ->
21:54:01.399 -> >>>stack>>>
21:54:01.399 ->
21:54:01.399 -> ctx: cont
21:54:01.399 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:54:01.437 -> 3ffffe60: 00000001 000001c0 00000001 4020773e
21:54:01.437 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:54:01.437 -> 3ffffe80: 00000001 3ffe88bf 3fff1db4 40217070
21:54:01.437 -> 3ffffe90: 40216a24 3fff05f0 3ffe9476 40207b7c
21:54:01.437 -> 3ffffea0: 3ffffef0 3ffffee0 0000000c 40216e0d
21:54:01.437 -> 3ffffeb0: 4027fb70 3ffe9404 3fff0330 0000075b
21:54:01.437 -> 3ffffec0: 4027fb70 3ffe9404 3fff0330 40201a8c
21:54:01.437 -> 3ffffed0: 00000000 4bc6a7f0 00000744 00000001
21:54:01.472 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:54:01.472 -> 3ffffef0: 00000001 656d6f68 65704f2f 54514d6e
21:54:01.472 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:54:01.472 -> 3fffff10: 574c2f54 3fff0054 3fff2de4 40224010
21:54:01.472 -> 3fffff20: 4652225b 50222c22 3fff2dac 40224a86
21:54:01.472 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:54:01.472 -> 3fffff40: 00000000 4bc6a7f0 00000743 00000000
21:54:01.509 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:54:01.509 -> 3fffff60: 4026d157 feefeffe 3fff04c0 40223b22
21:54:01.509 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:54:01.509 -> 3fffff80: 3fff0034 3ffeffa8 00000743 40205140
21:54:01.509 -> 3fffff90: feefeffe feefeffe feefeffe 3fff0730
21:54:01.509 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:54:01.509 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:54:01.509 -> <<<stack<<<
21:54:01.509 ->
21:54:01.509 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:01.547 ->
21:54:01.547 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:54:04.472 -> W: MQTT connection...
21:54:04.472 -> W: failure_number_mqtt: 1
21:54:04.472 -> W: failed, rc=-2
21:54:04.472 ->
21:54:04.472 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:04.472 ->
21:54:04.472 -> Exception (28):
21:54:04.472 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
21:54:04.472 ->
21:54:04.472 -> >>>stack>>>
21:54:04.509 ->
21:54:04.509 -> ctx: cont
21:54:04.509 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:54:04.509 -> 3ffffe60: 00000001 00000104 00000001 4020773e
21:54:04.509 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:54:04.509 -> 3ffffe80: 00000001 3ffe88bf 3fff17d4 40217070
21:54:04.509 -> 3ffffe90: 40216a24 3fff05f0 3ffe9476 40207b7c
21:54:04.509 -> 3ffffea0: 3ffffef0 3ffffee0 0000000c 40216e0d
21:54:04.509 -> 3ffffeb0: 4027fb70 3ffe9404 3fff0330 0000075b
21:54:04.509 -> 3ffffec0: 4027fb70 3ffe9404 3fff0330 40201a8c
21:54:04.509 -> 3ffffed0: 00000000 4bc6a7f0 00000b50 00000001
21:54:04.547 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:54:04.547 -> 3ffffef0: 00000001 656d6f68 65704f2f 54514d6e
21:54:04.547 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:54:04.547 -> 3fffff10: 574c2f54 3fff0054 3fff20e4 40224010
21:54:04.547 -> 3fffff20: 4652225b 50222c22 3fff20ac 40224a86
21:54:04.547 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:54:04.547 -> 3fffff40: 00000000 4bc6a7f0 00000b4f 00000000
21:54:04.547 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:54:04.585 -> 3fffff60: 4026d157 feefeffe 3fff04c0 40223b22
21:54:04.585 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:54:04.585 -> 3fffff80: 3fff0034 3ffeffa8 00000b4f 40205140
21:54:04.585 -> 3fffff90: feefeffe feefeffe feefeffe 3fff0730
21:54:04.585 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:54:04.585 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:54:04.585 -> <<<stack<<<
21:54:04.585 ->
21:54:04.585 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:04.622 ->
21:54:04.622 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:54:21.692 -> W: MQTT connection...
21:54:36.718 -> W: failure_number_mqtt: 3
21:54:36.718 -> W: failed, rc=-4
21:54:36.718 ->
21:54:36.718 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:36.718 ->
21:54:36.718 -> Exception (9):
21:54:36.718 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x00a600a6 depc=0x00000000
21:54:36.718 ->
21:54:36.718 -> >>>stack>>>
21:54:36.756 ->
21:54:36.756 -> ctx: cont
21:54:36.756 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:54:36.756 -> 3ffffe60: 00000003 00000000 00000001 4020773e
21:54:36.756 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:54:36.756 -> 3ffffe80: 00000001 3ffe88bf 0000032f 40100d53
21:54:36.756 -> 3ffffe90: 3fff20ac 3fffff00 3fff0e0c 00000002
21:54:36.756 -> 3ffffea0: 3fff20ac 00000000 00000020 40100fdb
21:54:36.756 -> 3ffffeb0: 4022af40 2303a8c0 3fff0330 00000002
21:54:36.756 -> 3ffffec0: 3fff20ac 3fff0e0c 3fffff00 4023495d
21:54:36.756 -> 3ffffed0: 00000000 4bc6a7f0 000042bc 00000001
21:54:36.790 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:54:36.790 -> 3ffffef0: 3fff20ac 656d6f68 65704f2f 54514d6e
21:54:36.790 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:54:36.790 -> 3fffff10: 574c2f54 3fff0054 3fff20e4 40224010
21:54:36.790 -> 3fffff20: 00000001 3fff0e0c 3fff20ac 40224ac7
21:54:36.790 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:54:36.790 -> 3fffff40: 00000000 4bc6a7f0 000042b9 00000000
21:54:36.826 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:54:36.826 -> 3fffff60: 4026d157 01656261 3fff04c0 40223b22
21:54:36.826 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:54:36.826 -> 3fffff80: 3fff0034 3ffeffa8 000042b9 40205140
21:54:36.826 -> 3fffff90: 3fffdad0 00000000 3fff06f0 3fff0730
21:54:36.826 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:54:36.826 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:54:36.826 -> <<<stack<<<
21:54:36.826 ->
21:54:36.826 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:36.863 ->
21:54:36.863 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:54:36.863 ->
21:54:36.863 -> load 0x4010f000, len 3584, room 16
21:54:54.803 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:54.803 ->
21:54:54.803 -> Exception (28):
21:54:54.803 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x04010400 depc=0x00000000
21:54:54.803 ->
21:54:54.803 -> >>>stack>>>
21:54:54.803 ->
21:54:54.803 -> ctx: cont
21:54:54.803 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:54:54.803 -> 3ffffe60: 00000001 00000000 00000001 4020773e
21:54:54.837 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:54:54.837 -> 3ffffe80: 00000001 3ffe88bf 3fff17d4 40217070
21:54:54.837 -> 3ffffe90: 40216a24 3fff05f0 3ffe9476 40207b7c
21:54:54.837 -> 3ffffea0: 3ffffef0 3ffffee0 0000000c 40216e0d
21:54:54.837 -> 3ffffeb0: 4027fb70 3ffe9404 3fff0330 0000075b
21:54:54.837 -> 3ffffec0: 4027fb70 3ffe9404 3fff0330 40201a8c
21:54:54.837 -> 3ffffed0: 00000000 4bc6a7f0 00000b58 00000001
21:54:54.837 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:54:54.872 -> 3ffffef0: 00000001 656d6f68 65704f2f 54514d6e
21:54:54.872 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:54:54.872 -> 3fffff10: 574c2f54 3fff0054 3fff20e4 40224010
21:54:54.872 -> 3fffff20: 4652225b 50222c22 3fff20ac 40224a86
21:54:54.872 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:54:54.872 -> 3fffff40: 00000000 4bc6a7f0 00000b58 00000000
21:54:54.872 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:54:54.872 -> 3fffff60: 4026d157 feefeffe 3fff04c0 40223b22
21:54:54.910 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:54:54.910 -> 3fffff80: 3fff0034 3ffeffa8 00000b58 40205140
21:54:54.910 -> 3fffff90: feefeffe feefeffe feefeffe 3fff0730
21:54:54.910 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:54:54.910 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:54:54.910 -> <<<stack<<<
21:54:54.910 ->
21:54:54.910 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:54:54.947 ->
21:54:54.947 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:54:54.947 ->
21:54:54.947 -> load 0x4010f000, len 3584, room 16
21:54:57.872 -> N: ************** Setup OpenMQTTGateway end **************
21:54:57.872 -> W: MQTT connection...
21:55:12.920 -> W: failure_number_mqtt: 1
21:55:12.920 -> W: failed, rc=-4
21:55:12.920 ->
21:55:12.920 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:55:12.920 ->
21:55:12.920 -> Exception (28):
21:55:12.920 -> epc1=0x4020b5cf epc2=0x00000000 epc3=0x00000000 excvaddr=0x04010400 depc=0x00000000
21:55:12.958 ->
21:55:12.958 -> >>>stack>>>
21:55:12.958 ->
21:55:12.958 -> ctx: cont
21:55:12.958 -> sp: 3ffffcd0 end: 3fffffc0 offset: 0190
21:55:12.958 -> 3ffffe60: 00000001 00000000 00000001 4020773e
21:55:12.958 -> 3ffffe70: 00000001 3ffeffa8 3fff0330 40201f46
21:55:12.958 -> 3ffffe80: 00000001 3ffe88bf 3fff17d4 40217070
21:55:12.958 -> 3ffffe90: 40216a24 3fff05f0 3ffe9476 40207b7c
21:55:12.958 -> 3ffffea0: 3ffffef0 3ffffee0 0000000c 40216e0d
21:55:12.958 -> 3ffffeb0: 4027fb70 3ffe9404 3fff0330 0000075b
21:55:12.995 -> 3ffffec0: 4027fb70 3ffe9404 3fff0330 40201a8c
21:55:12.995 -> 3ffffed0: 00000000 4bc6a7f0 00000b5a 00000001
21:55:12.995 -> 3ffffee0: 00000000 00000000 4bc6a7f0 00000000
21:55:12.995 -> 3ffffef0: 00000001 656d6f68 65704f2f 54514d6e
21:55:12.995 -> 3fffff00: 74614754 79617765 5053455f 5345545f
21:55:12.995 -> 3fffff10: 574c2f54 3fff0054 3fff20e4 40224010
21:55:12.995 -> 3fffff20: 4652225b 50222c22 3fff20ac 40224a86
21:55:12.995 -> 3fffff30: 4022af40 00000000 feefeffe feefeffe
21:55:12.995 -> 3fffff40: 00000000 4bc6a7f0 00000b5a 00000000
21:55:13.032 -> 3fffff50: 3fffdad0 3fff002c 3fff0e0c 402255e9
21:55:13.032 -> 3fffff60: 4026d157 feefeffe 3fff04c0 40223b22
21:55:13.032 -> 3fffff70: 3fff0034 3ffeffa8 3ffeffa8 00000000
21:55:13.032 -> 3fffff80: 3fff0034 3ffeffa8 00000b5a 40205140
21:55:13.032 -> 3fffff90: feefeffe feefeffe feefeffe 3fff0730
21:55:13.032 -> 3fffffa0: 3fffdad0 00000000 3fff06f0 402193c0
21:55:13.032 -> 3fffffb0: feefeffe feefeffe 3ffe86b8 401013b9
21:55:13.032 -> <<<stack<<<
21:55:13.032 ->
21:55:13.032 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
21:55:13.068 ->
21:55:13.068 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:55:13.068 ->
21:55:13.068 -> load 0x4010f000, len 3584, room 16
