Feature request: HOBO bluetooth sensors: MX2501
HOBO pH and Temperature Data Logger
Read 16-bit Little Endian Values
Sensor values are stored as 16-bit integers (LE) at fixed offsets.
From the packet:
Temperature raw: bytes [10..11]
mV raw: bytes [12..13]
Calibration Formulas:
// Temperature (°C)
const float T = -0.02541008336f * (float)ch0_le + 77.36404759f;
// mV
const float mV = 0.0156205128837f * (float)ch1_le - 511.890058384f;
// pH
const float pH = -0.0002918575538f * (float)ch1_le + 16.3797874314f;
These coefficients come from calibration experiments.
Battery Level:
Battery info is stored in byte [18]. Convert to bars and percentage:
const uint8_t b18 = d[18];
int bars = 0;
if (b18 >= 216) bars = 6;
else if (b18 >= 212) bars = 5;
else if (b18 >= 191) bars = 4;
else if (b18 >= 168) bars = 3;
else if (b18 >= 134) bars = 2;
else if (b18 >= 112) bars = 1;
else bars = 0;
Summary of Offsets:
FieldOffset (bytes)Format
Temp raw[10..11]LE uint16
mV raw[12..13]LE uint16
Battery[18]uint8
Packets and→ sensor values from app
hex ph temp C rms mV battery level
c5000b2072560100250000329f08165387732241dc 10.15 21.17 -179.6 6
c5000b207256010025000032a608df629caa0f41db 8.98 20.98 -116.52 6
c5000b207256010025000032a70879656e910c41dc 8.79 20.96 -106.11 6
c5000b207256010025000032a9088469c2c00741db 8.48 20.91 -89.94 6
c5000b207256010025020032a908856dd1fa0241dc 8.19 20.91 -73.92 6
c5000b207256010025000032ae08ff7a80d4e540dc 7.18 20.79 -20.02 6
c5000b207256010025020032b2082772ebeefa40dc 7.84 20.7 -55.39 6
c5000b207256010025020032b3081f729202fb40dc 7.84 20.67 -55.52 6
c5000b207256010025000032b408817358b6f740dc 7.74 20.65 -49.99 6
c5000b207256010025020032b40879a35b3d8540dc 4.16 20.65 141.89 6
c5000b207256010025020032b208f5a342198440dc 4.13 20.7 143.83 6
c5000b207256010025000032b1082fa4c7908340dc 4.11 20.72 144.74 6
c5000b207256010025020032af0872a4cdf48240dc 4.09 20.77 145.79 6
c5000b207256010025000032b80863941439a940db 5.6 17.82 64.05
c5000b2072560100250200322b090390fc3fb340dc 5.6 16.18 63.46
c5000b2072560100250200327009dd8f055bb340dc 5.66 15.06 60.08
c5000b2072560100250000329f09058f003cb540dc 7.72 14.1 56.63
c5000b207256010025020032de09978d6581b840dc 5.77 13.55 54.36
c5000b2072560100250000326e0a76883ab7c440dc 6.15 10.05 33.84
c5000b207256010025000032070b787a2175e740dc 7.23 6.23 -22.13
c5000b2072560100250200323d0bd5786e9feb40dd 7.36 4.84 -28.67
c5000b2072560100250200325e0bee7714f1ed40dc 7.44 3.98 -32.28
c5000b207256010025020032850b0e773237f040dc 7.51 2.96 -35.78
c5000b2072560100250200329c0bc676b2f7f040dc 7.54 2.13 -37.2
c5000b207256010025020032b50ba276305ef140db 7.54 1.59 -37.56
c5000b207256010025000032bc0b9a76b075f140dc 7.55 1.48 -37.59
c5000b207256010025020032c20b9b76ca75f140dc 7.55 1.32 -37.58
c5000B207256010025000032E405216741110941DC 8.57 38.87 -99.49
c5000B2072560100250000325005E86791DD0741DC 8.49 43.16 -96.38
c5000B2072560100250000320C05D267C7CD0741DC 8.49 45.25 -96.72
c5000B2072560100250000320C05D267C7CD0741DC 8.48 46.32 -96.63
c5000B207256010025000032DC049768EDD80641DC 8.43 46.77 -93.86
c5000b207256010025020001fe0f017e34c0dd40da 6
c5000b207256010025020001fe0f1508ae17ad41ce 4
c5000b207256010025020001fe0f9b1a6c9c9a41af 3
c5000b207256010025040001fe0f4b1815eb9c419f 2
c5000b207256010025000001fe0f0000fe27b54193 2
c5000b207256010025060001fe0f38001ff0b44179 1
c5000b207256010025020001fe0fa10a288daa4166 0
c5000b207256010025000001fe0f7b108cb6a441d6 5
https://www.onsetcomp.com/products/data-loggers/mx2501
